Directory name containing slashes??? [message #239721] |
Sun, 04 November 2007 23:23  |
Originally posted by: paul12345671.hotmail.com
I have a path displayed in the Package Explorer as
"WebContent/WEB-INF/src". I'd like to edit the faces-config file in the
WEB-INF directory. The trouble is that I can't list the contents of the
WEB-INF directory, because it's just displaying the slashes.
When I use windows explorer to view the folders, I can see the
faces-config file listed under WEB-INF. It's just that Eclipse isn't
displaying the hierarchy the way that I'd like it to.
I know that this will be basic, but could I please get someone to explain
how to display it as a hierarchy (with little +'s) rather than the path
(with slashes).
Thank you.
David.
Re: Directory name containing slashes??? [message #239741 is a reply to message #239721] |
Mon, 05 November 2007 06:39  |
David,
You'd likely be better to ask on the WTP newsgroup. I don't really
understand the problem you are describing but I suspect that if it's not
showing the content under that folder, it's showing the content
elsewhere in the view of that same project. Certainly if you use
"File->Show View->Navigator" it will show you more of a raw view of
what's actually there...
David wrote:
> Hello,
> the WEB-INF directory. The trouble is that I can't list the contents
> of the WEB-INF directory, because it's just displaying the slashes.
> explain how to display it as a hierarchy (with little +'s) rather than
> the path (with slashes).
> Thank you.
> David.
FUDForum. Page generated in 0.06585 seconds
