Home » Newcomers » Newcomers » Help Viewer error
Help Viewer error [message #239639] Sat, 03 November 2007 09:08 Go to next message
Originally posted by: wojtekmichalik.softtellco.com.pl
Help -> Help Contents
Opens browser window with title "Problems Viewing Page"
with contenst:
Unable to connect
Firefox can't establish a connection to the server at 127.0.0.1:59233.
* The site could be temporarily unavailable or too busy. Try again
in a few moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy,
make sure that Firefox is permitted to access the Web.
There are no problems viewing the same help from another user account.
Any clue what can be worng ??
Wojtek
Re: Help Viewer error [message #239649 is a reply to message #239639] Sat, 03 November 2007 11:56 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
1. Look at the firewall settings
2. I see you have changed which browser you are using. What happens when you use
the 'internal' browser?
Derek
> with contenst:
> Unable to connect
> in a few moments.
> connection.
> Regards
> Wojtek
Re: Help Viewer error [message #239687 is a reply to message #239649] Sun, 04 November 2007 05:14 Go to previous message
Does not have anything to do with this case I think - there is no firewall
> you use the 'internal' browser?
The same behavior I can observe with both browsers
I use eclipse Eclipse Platform
Version: 3.3.1.1
Build id: M20071023-1652
Linux with gtk.
It was installed in /usr/local/eclipse directory
This error does not appear when I set install directory access rights as
drwxrwxrwx
when directory access rights are drwxr-xr-x following exeption appears
ENTRY org.eclipse.help.base 4 0 2007-11-04 10:56:35.881
!MESSAGE An error occured while starting the help server
!STACK 0
java.lang.IllegalArgumentException: Bad temp directory: /usr/local/
eclipse/configuration/org.eclipse.osgi/bundles/600/data/jett ywork/
pid_2070971114
at org.mortbay.http.HttpContext.setTempDirectory
(HttpContext.java:975)
org.eclipse.equinox.http.jetty.internal.HttpServerManager.cr eateHttpContext
(HttpServerManager.java:247)
org.eclipse.equinox.http.jetty.internal.HttpServerManager.up dated
(HttpServerManager.java:103)
at org.eclipse.equinox.http.jetty.internal.Activator.startServe r
(Activator.java:208)
at org.eclipse.equinox.http.jetty.JettyConfigurator.startServer
(JettyConfigurator.java:60)
at org.eclipse.help.internal.server.WebappManager.start
(WebappManager.java:43)
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning
(BaseHelpSystem.java:187)
at org.eclipse.help.internal.base.HelpDisplay.displayHelpURL
(HelpDisplay.java:152)
(HelpDisplay.java:42)
at org.eclipse.help.ui.internal.DefaultHelpUI.displayHelp
(DefaultHelpUI.java:125)
at org.eclipse.ui.internal.help.WorkbenchHelpSystem.displayHelp
(WorkbenchHelpSystem.java:833)
at org.eclipse.ui.internal.actions.HelpContentsAction$1.run
(HelpContentsAction.java:83)
at org.eclipse.swt.custom.BusyIndicator.showWhile
(BusyIndicator.java:67)
at org.eclipse.ui.internal.actions.HelpContentsAction.run
(HelpContentsAction.java:81)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$2
(ActionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t
(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents
(Display.java:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2971)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.core.databinding.observable.Realm.runWithDefault
(Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:461)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start
(IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run
(EclipseAppHandle.java:169)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication
(EclipseAppLauncher.java:106)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start
(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:363)
(EclipseStarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework
(Main.java:508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Previous Topic:Installation - Java and C++
Next Topic:Including resources in a project
Current Time: Tue Jul 22 15:34:16 EDT 2025
Powered by FUDForum. Page generated in 0.09106 seconds
