Minimum Requirements for Mylyn Trac [message #23476] |
Tue, 21 August 2007 16:07  |
Originally posted by: daniel.dzone.com
What are the minimum requirements for Mylyn to integrate with Trac fully? Obviously the XML-RPC plugin, but is there a specific version which is required? Also, are there any specific URLs that Mylyn hits during the synchronization process which must be present in order for Mylyn to function appropriately?
Re: Minimum Requirements for Mylyn Trac [message #24586 is a reply to message #23476] |
Wed, 29 August 2007 02:09  |
XML-RPC access:
- Trac XmlRpcPlugin (revision 1950 or later) and sufficient repository
permissons to use it
- The expected URL is either /xmlrpc or /login/xmlrpc (if login credentials
are provided)
Web access:
- Authentication: /login
- Querying: /query?format=tab...
- Synchronizing ticket details: /ticket/...
- Getting repository configuration to populate query dialog: /query
or /newticket
The web mode relies on screen scraping and is likely to fail if the design
(i.e. HTML output) of the Trac repository is heavily customized.
Also note that at this point only Trac 0.9.x and Trac 0.10.x are supported:
175211: Support Trac 0.11
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175211
A patch exists to get the XmlRpcPlugin working with Trac 0.11 but I haven't
tested the latest revisions with Mylyn, yet. Web mode has not been updated
for Trac 0.11, yet, since the HTML output generated by Trac has changed
significantly.
Please open a bug report in case you experience problems with a particular
Trac instance so we can iterate to improve support for customized
repositories on the Mylyn side.
Steffen
Re: Minimum Requirements for Mylyn Trac [message #578917 is a reply to message #23476] |
XML-RPC access:
are provided)
Web access:
or /newticket
significantly.
Steffen
FUDForum. Page generated in 0.04299 seconds
