Home » Archived » BIRT » Opening xml based reports generated with Runtime engine 2.1.2 in web servlet of version 2.2. m6
Opening xml based reports generated with Runtime engine 2.1.2 in web servlet of version 2.2. m6 [message #239187] Tue, 22 May 2007 06:23 Go to next message
Originally posted by: Arthur1968.gmail.com
When I open an xml based report generated with Runtime engine 2.1.2 in the
web servlet of version 2.2. m6 it cannot render the output.
I get this error:
org.eclipse.birt.data.engine.core.DataException: Column binding "field100"
has referred to a data set column "field100" which is not exist.
The report renders fine in the 2.1 servlet.
I create the dataset with:
DataSetHandle datasetHandle = null;
datasetHandle = mElementFactory.newOdaDataSet( "DataSet",
"org.eclipse.birt.report.data.oda.xml.dataSet" );
datasetHandle.setDataSource( "DataSource" );
mReportDesignHandle.getDataSets( ).add( datasetHandle );
return datasetHandle;
and the datasource with:
mDataSourceHandle = mElementFactory.newOdaDataSource("DataSource",
"org.eclipse.birt.report.data.oda.xml");
mDataSourceHandle.setProperty("FILELIST", sDataSource);
mReportDesignHandle.getDataSources( ).add( mDataSourceHandle );
Any hints or people with the same issue?
Thanks in advance
Ron
Re: Opening xml based reports generated with Runtime engine 2.1.2 in web servlet of version 2.2. m6 [message #239437 is a reply to message #239187] Tue, 22 May 2007 16:13 Go to previous messageGo to next message
This looks like a binding issue.
Can you post the completed rptdesign?
Jason
> I get this error:
> Thanks in advance
> Ron
Re: Opening xml based reports generated with Runtime engine 2.1.2 in web servlet of version 2.2. m6 [message #239451 is a reply to message #239187] Tue, 22 May 2007 16:38 Go to previous messageGo to next message
Originally posted by: xxxx.xxx.com
Is you dataset built with temporary tables?
Re: Opening xml based reports generated with Runtime engine 2.1.2 in web servlet of version 2.2. m6 [message #239579 is a reply to message #239451] Wed, 23 May 2007 09:47 Go to previous message
No, this is just one xml file and Birt retrieves the data with XPATH.
Ron
"Birt Guy" <xxxx@xxx.com> wrote in message
news:0731a07e75cc18805d81e58546bd7b81$1@www.eclipse.org...
Previous Topic:secured xml data source ...
Next Topic:Errors starting BIRT Runtime Engine
Current Time: Sat Aug 30 06:20:55 EDT 2025
Powered by FUDForum. Page generated in 0.03528 seconds
