Home » Archived » Java WorkFlow Tooling (JWT) » JWT checkpoint
JWT checkpoint [message #23403] Thu, 16 November 2006 09:26 Go to next message
Originally posted by: marc.dutoo.laposte.net
Here is today's checkpoint :
board :
alain Boulzes ok
gunther ok
TODO think about the board roles' missions
proposal :
schemas sent at start of the week
friday the 24th final proposal validation
TODO write that agilPro as likely start
roadmap :
* decision process on the model
* decision process on languages and engines (includes studies, proof a
concept if needed)
* making the model flexible, singleing out extension points in it for
gram, repr, biz views
* actual impl over a chosen language *2
* 1.0 packaging
* WAM another decision process about engines
* WAM : process management API
* WAM : dummy versions of other APIs needed for a basic version
* WAM 1.0 packaging
* other tracks : still WE impls, SCOrWare contributions, AgilPro
contributions...
TODO talk to bjorn
Best regards !
Marc Dutoo
Open Wide
Reworked JWT proposal [message #23444 is a reply to message #23403] Thu, 23 November 2006 17:46 Go to previous messageGo to next message
Hi all
There is a reworked version of the JWT proposal available at the
following URL :
http://pvs.informatik.uni-augsburg.de/phprojekt/addons/addon .php?addon=Wiki&id=JWT
It has been updated according to the most recent elements (including
architecture schemas, board definition and initial roadmap). "With some
luck", this should be the final one.
You're more than welcome to read it, in order to send any feedback - or
to scout for spelling errors ! For those available, we'll try to
schedule an internal validation telco tomorrow.
Best regards
Marc Dutoo
Open Wide
Re: Reworked JWT proposal [message #23488 is a reply to message #23444] Mon, 27 November 2006 08:37 Go to previous messageGo to next message
Hi Oisin
The proposal wiki is accessible with the login "jwt" and the password
"we_wam" at the URL
.. I also enclosed it in this mail, but you won't have the images.
Actually I learned only recently from Bjorn there was already an eclipse
Wiki...
I'm looking forward to any feedback you may have. Anyway, we'll have to
talk some more ;)
Marc Dutoo
Open Wide
Hurley, Oisin wrote:
>Hi Marc,
>There's a login required for the URL
>iki&id=JWT
>and I don't have the required login/username.
>Can I get a copy of the proposal draft in some
>other fashion?
> best regards
> Oisin
[Fwd: Re: XPDL generation contribution] [message #23531 is a reply to message #23403] Fri, 01 December 2006 04:49 Go to previous message
About the Obj. Eng. XPDL mapping contribution
Thank you very much !
This helps envisioning the support of XPDL in JWT. The fact that the
export feature is implemented (as well as the import) is great news.
Best Regards
Marc Dutoo
Open Wide
Roman Zulauf wrote:
> Dear Marc
> Marc Dutoo wrote:
>> Hi Roman
>> We still plan to support XPDL in JWT, and in this light your old
Object Engineering contribution is valuable, at least for ideas or even
to enable us to have quickly a first XPDL mapping by translating to your
model. So I've got a few questions about it ^^
>> I've looked at the code in AWF_common, and it pretty much looks like
there is
>> * a complete XPDL model
> It is s more or less complete XPDL model (XPDL Version 1.0). There
are things missing like
> - ActivitySets
> - BlockActivities
> - DeclaredTypes
> - ExternalPackages
> - TypeDeclarations
>> * a complete XPDL importer (or to what extent ?)
> It is complete to the degree as stated above.
>> * but only a stub XPDL exporter : XPDLExportVisitor.java is empty
- or am I mistaken ? But I guess it shouldn't be difficult...
> That class seems to be an old leftover (sorry for that). The export
code is located here:
> ch\objeng\appl\eias\awf\common\model\exports\xpdl\XPDLExport Handler.java
> Hope that helps. If you have any more questions I'd be glad to help
you jump start on this.
> Best regards,
> Roman
Previous Topic:New JWT proposal draft Wiki
Next Topic:JWT "Project Wiki" on Eclipse.org
Current Time: Sat Jul 26 19:51:27 EDT 2025
Powered by FUDForum. Page generated in 0.31923 seconds
