Home » Modeling » GMF (Graphical Modeling Framework) » Can't find genClass for class 'MyClass' in package myPckage
Can't find genClass for class 'MyClass' in package myPckage [message #23387] Fri, 18 August 2006 11:11 Go to next message
I get the following message when invoke "Create generator model..." in
gmfmap file. Does anyone know what the cause is ????
An internal error occurred during: "Create generator model...".
java.lang.IllegalStateException: Can't find genClass for class 'MyClass'
in package myPckage
org.eclipse.gmf.internal.bridge.genmodel.GenModelMatcher.fin dGenClass(GenModelMatcher.java:82)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.findGenClass(DiagramGenModelTransformer.java:638)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.setupModelFacet(DiagramGenModelTransformer.java:699)
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.createModelFacet(DiagramGenModelTransformer.java:658 )
org.eclipse.gmf.internal.bridge.genmodel.DiagramGenModelTran sformer.process(DiagramGenModelTransformer.java:241)
org.eclipse.gmf.internal.bridge.genmodel.MappingTransformer. transform(MappingTransformer.java:32)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$1.transform(TransformToGenModel.java:189)
org.eclipse.gmf.internal.codegen.popup.actions.TransformToGe nModel$1.run(TransformToGenModel.java:159)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Re: Can't find genClass for class 'MyClass' in package myPckage [message #23688 is a reply to message #23387] Fri, 18 August 2006 15:04 Go to previous messageGo to next message
I had the same problem. Changes to the ecore diagram (new class) does not
change the existing genmodel file, although then genmodel editor shows the
new class, but the genmodel xml file does not contain the new class. Delete
the genmodel file and recreate it solves the problem.
Hope this helps.
Wolfgang
"Sakae Nakajima" <sakae55@gmail.com> schrieb im Newsbeitrag
news:ec4lae$bfm$1@utils.eclipse.org...
> in package myPckage
> at
> at
> at
> at
> at
> at
> at
> at
Tutorial - Audit doesn´t work [message #23731 is a reply to message #23688] Fri, 18 August 2006 16:26 Go to previous messageGo to next message
Originally posted by: leonardo.coelho.siliconstrategy.com.br
Hi, guys, i´m a newbie and it´s my second day working with GMF.
I´ve downloaded the MindMap tutorial 2 source code and it doesn´t work.
Can everybody help me? I´ve followed all tutorial instructions.
The first example works well and everything is ok, except audit and the
problem with the duplicate graphical link.
By the way, is there a new eclipse environment download available? Of
course, with duplicate graphical link corrected!
Regards!
Leonardo Coelho
Re: Tutorial - Audit doesn´t work [message #23775 is a reply to message #23731] Fri, 18 August 2006 16:30 Go to previous messageGo to next message
The latest working (fixed duplicate links) code is in CVS, and in the
provided solution zips (as of yesterday).
Can you provide more detail on the problem with the audits? Are there any
error log entries?
Rich
On 8/18/06 4:26 PM, in article ec57ln$au7$1@utils.eclipse.org, "Leonardo
> Regards!
Re: Can't find genClass for class 'MyClass' in package myPckage [message #24299 is a reply to message #23688] Mon, 21 August 2006 04:53 Go to previous messageGo to next message
Thanks very much.
Your advice worked for me.
> Hope this helps.
> Wolfgang
>> in package myPckage
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Can't find genClass for class 'MyClass' in package myPckage [message #1044114 is a reply to message #24299] Thu, 18 April 2013 10:04 Go to previous message
In the end that causes this error: "can not find GenClass for class in package"???
Unable to find a clear solution for the!
Previous Topic:Best practice
Next Topic:How to add EClass objects programmatically to a diagram?
Current Time: Sat Jul 26 19:50:29 EDT 2025
Powered by FUDForum. Page generated in 0.07167 seconds
