Home » Eclipse Projects » Eclipse Platform » Could not find bootstrap code
Could not find bootstrap code [message #238622] Tue, 04 May 2004 16:17 Go to next message
Originally posted by: sengbeo.bite.com.sg
Hi ALL,
Am running on WinXP and get same error trying to start eclipse from DOS
prompt and explorer.
Am running JRE Java(TM) Plug-in: Version 1.3.1_11 but I don't think that's
the problem.
Do I need to set the "PATH" or some system environment to the eclipse main
directory or should eclipse automatically find the bootstrap from where it
was started ?
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 May 05, 2004 03:30:32.357
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find bootstrap code. Check location of
boot plug-in or specify -boot.
at org.eclipse.core.launcher.Main.searchForBoot(Main.java:468)
at org.eclipse.core.launcher.Main.getBootPath(Main.java:438)
at org.eclipse.core.launcher.Main.basicRun(Main.java:281)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Re: Could not find bootstrap code [message #238743 is a reply to message #238622] Wed, 05 May 2004 04:52 Go to previous message
> the problem.
Which version of eclipse are you running? For the 3.0 milestone you will
need a 1.4.1 level or higher Java.
Did you read
https://bugs.eclipse.org/bugs/show_bug.cgi?id=35718
and see whether the issues there apply?
marko
Previous Topic:Ordering entries in new project wizard
Next Topic:Marker update problem in the problem view
Current Time: Sat Jul 26 18:15:08 EDT 2025
Powered by FUDForum. Page generated in 0.03939 seconds
