Home » Modeling » GMF (Graphical Modeling Framework) » outline view for edges
outline view for edges [message #23341] Fri, 18 August 2006 11:03 Go to next message
Originally posted by: hartmut.linke.ast.iitb.fraunhofer.de
I'm working on an editor to define a water supply system. I'd like to
include all network elements into the outline view (nodes as well as
edges (e.g. pipes, channels)). Is it possible to extend the default
outline view in the desired manner?
Thanks in advance,
Hartmut
Re: outline view for edges [message #23430 is a reply to message #23341] Fri, 18 August 2006 12:06 Go to previous messageGo to next message
h_linke wrote:
> Thanks in advance,
> Hartmut
Hi;
Edges on the diagram surface should show up in the outline view, check
the Logic example
Re: outline view for edges [message #24544 is a reply to message #23430] Mon, 21 August 2006 08:18 Go to previous messageGo to next message
Mohammed Mostafa wrote:
> Hi;
> check the Logic example
Hi Mohammed,
sorry, but i can't observe the desired behavoir in the Logic example.
Probably my problem description was not precise enough. I'm only
interested in a tree outline view. Referring to the Logic example: If i
draw a connection between two logic elements (e. g. two gates), this
connection should be visible as one item in the tree outline view.
If your configuration shows this behavior, where can i define, that
connections have to be included into the tree outline view?
Hartmut
Re: outline view for edges [message #24662 is a reply to message #24544] Mon, 21 August 2006 09:47 Go to previous messageGo to next message
>> Hi;
> Hi Mohammed,
> Hartmut
The Edges are displayed in the outline view when you select the OverView
mode, in tree mode we do not display connections
if you want to change this behavior check
DiagramOutlinePage , and TreeContainerEditPart
Re: outline view for edges [message #25221 is a reply to message #24662] Tue, 22 August 2006 04:54 Go to previous message
Thanks for your advice!
Hartmut
Previous Topic:Icons in the outline's tree view
Next Topic:Property view: Filter list of multivalued property
Current Time: Sat Jul 26 06:04:10 EDT 2025
Powered by FUDForum. Page generated in 0.05846 seconds
