Unable to build Buckminster Site from SVN [message #23330] |
Tue, 05 August 2008 05:33  |
Hi there,
I'm trying to compile buckminster site from SVN but the project org.eclipse.buckminster.test does not compile.
> MimeUtility cannot be resolved TestRunner.java org.eclipse.buckminster.test/src/org/eclipse/buckminster/tes t/junit line 177
> The import javax.mail cannot be resolved TestRunner.java org.eclipse.buckminster.test/src/org/eclipse/buckminster/tes t/junit line 23
When I try to build the site :
org.eclipse.buckminster.update#build.site
I have the following message :
> org.eclipse.core.runtime.CoreException: Basedir T:\travail\src\BuckminsterWorkspace\plugins\javax.mail does not exist
The problem is eclipse uses javax.mail from my eclipse installation :
L:\eclipse\plugins\javax.mail_1.4.0.v200804091730
And it seems not to provide all the files needed by org.eclipse.buckminster.test, plus buckminster's build.site action tries to access javax.mail in the workspace and not the featured eclipse plugin.
I will try to add constrains to the query to force materialization, but I think it's worth warning.
By the way, is "executing the org.eclipse.buckminster.update#build.site" the good way to build a site with all the features like the one at : http://download.eclipse.org/tools/buckminster/updates
Guillaume
Re: Unable to build Buckminster Site from SVN [message #23419 is a reply to message #23330] |
Tue, 05 August 2008 05:48  |
Guillaume CHATELET wrote:
> Hi there,
>> line 177
>> line 23
>> not exist
This is odd. Did you materialize the javax.mail into that location
earlier and then removed it?
Buckminster should try to access whatever it resolved in the last
cquery. It will not access the workspace at random. Somehow, at some
point, it must have been made to believe that a javax.mail indeed was
present in the workspace.
That's the only way you can build it yourself since signing privileges
at eclipse.org is required in order to build the final update site (only
two committers per project are assigned those privileges). The full
build is in the top-level project, i.e. org.eclipse.buckminster#build.site
Thomas Hallgren
FUDForum. Page generated in 0.10570 seconds
