Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Include resources into the JAR
Include resources into the JAR [message #23304] Wed, 26 November 2008 18:12 Go to next message
Originally posted by: news.s237965939.online.de
In my application there are images to display in forms. I can load them
from disk on the emulator. I've also imported the image in the elipse
project 'res' package/folder. But how will it go into the jar file and
how do I refer to it from the sourcecode? Currently I'm doing
Image image = Image.createImage( "/myPictue.jpg" );
picAlert.setImage(image);
TIA,
Hans
Re: Include resources into the JAR [message #23346 is a reply to message #23304] Thu, 27 November 2008 04:44 Go to previous messageGo to next message
Ok folks, I found the answer myself. This works for me:
InputStream is = Object.class.getResourceAsStream("/mypic.jpg");
Image image = Image.createImage( is );
Thanks for reading,
Hans
Re: Include resources into the JAR [message #23473 is a reply to message #23304] Thu, 27 November 2008 08:10 Go to previous messageGo to next message
Hello Hans,
The content in the source folders go into the JAR root, so for example if
you put a 'myPictue.jpg' in the root of a source folder it will be on the
JAR`s root and can be accessed with '/myPictue.jpg'. Just make sure your
'res' folder is a source folder and it should work fine.
David Marques
Re: Include resources into the JAR [message #23558 is a reply to message #23473] Thu, 27 November 2008 12:41 Go to previous message
Thanks David. As I wrote in my other post I've finally figured it out. Ended
up with simple two lines of code and the correct configuration.
THX,
Hans
"David Marques" <wtv368@motorola.com> wrote
> Hello Hans,
> David Marques
Re: Include resources into the JAR [message #568716 is a reply to message #23304] Thu, 27 November 2008 04:44 Go to previous message
Thanks for reading,
Hans
Re: Include resources into the JAR [message #568775 is a reply to message #23304] Thu, 27 November 2008 08:10 Go to previous message
Hello Hans,
David Marques
Re: Include resources into the JAR [message #568818 is a reply to message #23473] Thu, 27 November 2008 12:41 Go to previous message
THX,
Hans
> Hello Hans,
> David Marques
Previous Topic:Error reading a bean with an attribute "array of strings" from Axis WS
Next Topic:External JAR File
Current Time: Sat Jul 26 03:04:02 EDT 2025
Powered by FUDForum. Page generated in 0.06221 seconds
