Home » Eclipse Projects » Nebula » Selection event from grid when checking check box.
Selection event from grid when checking check box. [message #23281] Wed, 10 January 2007 10:10 Go to next message
Originally posted by: johan.kannala.comsol.com
Hi Chris! =)
I noticed that if I have a grid column with check boxes, I get a
selection event when I check or un-check a check box, even though the
"real selection" in the grid (the blue cells) hasn't changed. Is this
the intended behavior or should I file a bug report?
/Johan
Re: Selection event from grid when checking check box. [message #23306 is a reply to message #23281] Wed, 10 January 2007 10:17 Go to previous message
Hi Johan,
Yes its intended. This matches how the normal Table works. When the
selection event is triggered due to a checkbox change the event.detail =
SWT.CHECK and event.index = column of containing the checkbox.
-Chris
Johan Kannala wrote:
> Hi Chris! =)
> /Johan
Re: Selection event from grid when checking check box. [message #574923 is a reply to message #23281] Wed, 10 January 2007 10:17 Go to previous message
Hi Johan,
-Chris
> Hi Chris! =)
> /Johan
Previous Topic:Selection event from grid when checking check box.
Next Topic:Using CompositeTable as a basic Table replacement
Current Time: Sat Aug 30 22:19:26 EDT 2025
Powered by FUDForum. Page generated in 0.03817 seconds
