Home » Eclipse Projects » Subversive » strange error on commit
strange error on commit [message #23276] Wed, 02 July 2008 02:20 Go to next message
Originally posted by: info.davideparisi.com
Hy, i have a strange error using subversive on eclipse 3.3.2 Europa.
In past days all working fine.
Now when i try to commit resource whit subversive i got an error:
Some of selected resources were not committed.
svn: Commit failed (details follow):
svn: MKACTIVITY request failed on
'/svn/!svn/act/915168e2-1a01-0010-a16a-35fba7ad6609'
svn: MKACTIVITY of '/svn/!svn/act/915168e2-1a01-0010-a16a-35fba7ad6609':
400 Bad Request (http://192.168.2.11)
I'm in Intranet (without proxy and firewall) and other clients working
fine and commiting in the same repository.
The authentication also seems to work ok, i can update and browse the
repos (only the commit don't work).
Now i workaround and for commit use Tortoise SVN but i want to use only
Eclispe & Subversive.
My repository serve is an Apache (not svnserve), but, i repeat, all
working fine in past days!!...:(
Can anyone help me? any ideas?
Thanks at all
Davide
Re: strange error on commit [message #23375 is a reply to message #23276] Wed, 02 July 2008 08:45 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Davide,
It looks like protocol failure and its reason is unclean. But if you sure
that Tortoise SVN works fine, you can try to switch SVN connector library
to the native one (JavaHL) at Window->Preferences->Team->SVN->SVN
Connector.
In case if problem is solved in the way described above, I think you can
try ask SVN Kit connector library developers for possible solutions
(http://svnkit.com).
Re: strange error on commit [message #23806 is a reply to message #23375] Wed, 02 July 2008 13:34 Go to previous message
IT working!!!!
Many many thanks!
Previous Topic:feature request: tagging with current position in the tree
Next Topic:Ganymede Subversive - Compare/Replace with version from Repository
Current Time: Sun Aug 31 03:52:42 EDT 2025
Powered by FUDForum. Page generated in 0.03550 seconds
