run jet2 outside of eclipse [message #23139] |
Wed, 20 June 2007 14:04  |
Hi Paul,
Just one question, is it possible to run jet2 outside of Eclipse?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: run jet2 outside of eclipse [message #23216 is a reply to message #23139] |
Thu, 21 June 2007 00:44   |
Originally posted by: evaandoli.dodo.com.au
A previous reply from Paul on this:
Frederic:
Thanks for the feedback.
I cannot guarantee that the refactoring will be completed by this June's
release - in particular, it is unlikely I'll have tag libraries that will
work outside of a full workbench.
The JET 0.8.0M6 build has a new plug-in, org.eclipse.jet.core, which is
largely free of Eclipse dependencies (except for org.eclipse.text - I will
have to remove some deprecated methods to eliminate that). But,
org.eclipse.jet.core does not yet include any tag library implementations,
nor does it include equivalents to JET2Platform.runTransformXXX().
Paul
"Frederic" <f.bighelli@diginext.fr> wrote in message
news:96be233fbcd1d8b51996c99af133c4b8$1@www.eclipse.org...
> Thanks for your response.
> Do you have a dead line for the first refactored version of JET2?
> For your question,i suggest yes for a subset (tag copyfile,file and
> folder) of JET Workspace in particular case where the target environment
> is outside Eclipse
> environment (this is my case and... sometimes there is no other
> possibility).
"Martin Taal" <mtaal@elver.org> wrote in message
news:f5bq7o$7vc$1@build.eclipse.org...
> Hi Paul,
> The Netherlands
Re: run jet2 outside of eclipse [message #23757 is a reply to message #23633] |
Sun, 24 June 2007 14:28  |
Paul,
I prefer only dependencies on pure java and possibly some generic java libs (commons-logging etc.).
I want to use jet for generation of jsf web views. Btw, I just mean the actual transformation. So
the templates are developed/created in an eclipse environment.
gr. Martin
Paul Elder wrote:
> Martin:
> So my question to you is, how outside do you want to be?
> Is a dependency on Equinox OK? Or, do you want only dependencies on pure
> Java?
> I am very likely to try to do something in the next release, but I'm not
> clear yet on what the community wants or needs.
> You feed back would be much appreciated.
> Paul
>> Hi Paul,
>> The Netherlands
The Netherlands
FUDForum. Page generated in 0.03312 seconds
