Home » Archived » Visual Editor (VE) » Support for actions in GUI builder?
Support for actions in GUI builder? [message #23082] Fri, 05 March 2004 06:14 Go to next message
Originally posted by: jens.ohlsson.sverige.nu
Are there any plans for supporting actions, as a complement/replacement
for implement actionPerformed, in the GUI-editor?
Re: Support for actions in GUI builder? [message #23125 is a reply to message #23082] Fri, 05 March 2004 08:39 Go to previous messageGo to next message
No short term plans for Action. You can open an enhancement bugzilla.
Re: Support for actions in GUI builder? [message #23245 is a reply to message #23082] Fri, 05 March 2004 18:53 Go to previous messageGo to next message
Jenson,
Question - how would you like to see this done ?
Is this acceptable:
select the action property - the cell editor has a ... button that opens a
dialog
The dialog shows you all compatible classes in the class path, i.e.
implementors of javax.swing.Action. The list would be filtered to exclude
abstract classes or those without a null constructor. You could choose
one and then we'd do all the magic to add a variable, new it up, and set
the property value.
We could do something with the JavaBeans tree viewer as well to show that
there was an action associated with the JButton.
Or...
do you want instead us to code generate something for you when the events >
actionPerformed menu is chosen such as an implementation of an Action inner
class that is added as a property (instead of the anonymous ActionListener
we currently create).
As Gili said nothing is in plan, but I'm keen to hear your design ideas so
once we have a buzailla feature request we can size up what kind of
solution you're looking for.
Joe
Re: Support for actions in GUI builder? [message #23519 is a reply to message #23245] Mon, 08 March 2004 16:37 Go to previous message
Originally posted by: lee.leemeador.com
Some thoughts, perhaps duplicating prior ones.
How about selecting an existing class by name and generating a 'new' one
with or without an anonymous inner subclass.
Or let the user pop up the 'new class' box from there with some limits on
the allowable parent classes. Then it could generate a top-level class or
inner class to handle the Action responsibilites.
Joe Winchester wrote:
> Jenson,
> Is this acceptable:
> dialog
> the property value.
> Or...
> Best regards,
> Joe
Re: Support for actions in GUI builder? [message #583566 is a reply to message #23082] Fri, 05 March 2004 08:39 Go to previous message
Re: Support for actions in GUI builder? [message #583599 is a reply to message #23082] Fri, 05 March 2004 18:53 Go to previous message
Jenson,
Is this acceptable:
dialog
the property value.
Or...
Joe
Re: Support for actions in GUI builder? [message #583778 is a reply to message #23245] Mon, 08 March 2004 16:37 Go to previous message
> Jenson,
> Is this acceptable:
> dialog
> the property value.
> Or...
> Best regards,
> Joe
Previous Topic:CDE plugin in internal packages
Next Topic:BoxLayout
Current Time: Fri Jul 04 23:51:08 EDT 2025
Powered by FUDForum. Page generated in 0.24967 seconds
