Home » Eclipse Projects » JFace » [databinding] ControlDecorationSupport feedback: provide access to the ControlDecoration
[databinding] ControlDecorationSupport feedback: provide access to the ControlDecoration [message #23073] Wed, 22 July 2009 17:08 Go to next message
When using ControlDecorationSupport, the ControlDecoration is created
internally and not directly accessible. I need to set the ControlDecoration
as data on the Control (for testing purposes) and the only way I can see to
do it is to provide a custom ControlDecorationUpdater that does this on
every update:
protected void update(ControlDecoration decoration, IStatus status) {
decoration.getControl().setData("CONTROL_DECORATION", decoration);
super.update(decoration, status);
Re: [databinding] ControlDecorationSupport feedback: provide access to the ControlDecoration [message #23222 is a reply to message #23073] Wed, 22 July 2009 17:23 Go to previous messageGo to next message
Would you file a bug for this?
Matthew
> ControlDecoration as data on the Control (for testing purposes) and the
> only way I can see to do it is to provide a custom
> ControlDecorationUpdater that does this on every update:
Re: [databinding] ControlDecorationSupport feedback: provide access to the ControlDecoration [message #23663 is a reply to message #23222] Thu, 23 July 2009 20:17 Go to previous message
http://bugs.eclipse.org/284521
"Matthew Hall" <matthall@woodcraftmill.com> wrote in message
news:h47vvt$5dj$3@build.eclipse.org...
> Matthew
Previous Topic:[databinding] ControlDecorationSupport idea
Next Topic:Add hyperlink control to the end of a TableViewer
Current Time: Sat Aug 30 19:46:37 EDT 2025
Powered by FUDForum. Page generated in 0.04095 seconds
