problems on linux motif with text widgets [message #235747] |
Wed, 28 April 2004 05:35  |
Hi all,
I've a problem to write text in a text widget. With win32 and OSX all
works fine, but some strange behaviour under linux(Debian 3.0) .
I've tried libs like swt-2.1.3-linux-motif and swt-3.0M8-linux-motif,
exported the LD_Library path, e.g. :
export
LD_LIBRARY_PATH=/lib:/home/niemeand/SWT_TESTS/lib/swt-2.1.3- linux-motif
and stripped down my program basically to pin down the problem.
The code is packed in a jar ball with following manifest.mf sets:
Manifest-Version: 1.0
Main-Class: project.progs.LoginWindowTest
Class-Path: lib/swt-2.1.3-linux-motif/swt.jar
The JRE is:
java version "1.4.1_03"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.1_03-b02)
Java HotSpot(TM) Client VM (build 1.4.1_03-b02, mixed mode)
Testing by using X11 and export the display to another debian box and my
apple.
I assume that I forgot a required property to that code.
Many thanks for any hint.
Andreas
Here the simple code snippet:
import org.eclipse.swt.*;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.layout.*;
* @author niemeand
public class LoginWindowTest {
doCreateLoginScreen();
public static void doCreateLoginScreen() {
Display vDisplay = new Display();
final Shell vShell = new Shell(vDisplay, SWT.ON_TOP);
vShell.setLayout(new FillLayout(SWT.VERTICAL));
Text vUser = new Text(vShell, SWT.BORDER);
vUser.setSize(180, 20);
Button vButtonCancel = new Button(vShell, SWT.FLAT);
vButtonCancel.setText("cancel");
vButtonCancel.setSize(180, 20);
vButtonCancel.addSelectionListener(new SelectionAdapter () {
public void widgetSelected(SelectionEvent e) {
vShell.close();
vShell.pack();
vShell.setLocation((vDisplay.getBounds().width -
vShell.getBounds().width) / 2,
(vDisplay.getBounds().height - vShell.getBounds().height) / 2);
vShell.open();
while (! vShell.isDisposed()) {
if (! vDisplay.readAndDispatch()) vDisplay.sleep();
vDisplay.dispose();
Re: problems on linux motif with text widgets [message #235821 is a reply to message #235747] |
Wed, 28 April 2004 08:22   |
Andreas,
The problem is the different swt implementations of ON_TOP Shells across the
platforms. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=32240.
The only workaround I can suggest is to not use ON_TOP if possible. Can you
use NO_TRIM instead (ie.- same appearance but without the ON_TOP behaviour)?
This is of course dependent upon your specific use context.
Grant
"Andreas Niemeyer" <andreas.niemeyer@gutzmann.com> wrote in message
news:c6ntgu$iel$1@eclipse.org...
> Hi all,
> export
> The JRE is:
> apple.
> Cheers,
> Andreas
> * @author niemeand
> public static void main(String[] args) {
> vShell.close();
> vShell.pack();
> vShell.open();
> vDisplay.dispose();
FUDForum. Page generated in 0.05007 seconds
