Home » Language IDEs » Java Development Tools (JDT) » cannot load a class at runtime / REWARD OFFERED... :)
cannot load a class at runtime / REWARD OFFERED... :) [message #235603] Wed, 06 September 2006 09:46 Go to next message
Hi / here is a previous post, I am still lost on this one...
I will happily send a reward for first clue that gets me unstuck...
....you get to pick one of:
(1) the music CD of your choice from Amazon
(2) a frisbee, but, like, a nice frisbee or
(3) a really good Russian novel.
Here is the problem:
I cannot load org.eclipse.debug.core.DebugPlugin at runtime.
Here is a simple code sample that refers to DebugPlugin:
DebugPlugin dpi = DebugPlugin.getDefault();
MessageDialog.openInformation(
window.getShell(),
"HelloDebug Plug-in",
dpi.toString());
1. if I make a Hello World plugin and insert this code, it works fine,
both running under the debugger and deployed in a JAR under a clean copy
of Eclipse.
2. if I insert the code into the plugin that I am actually developing...
2.1 it works fine under the debugger.
2.2 when deployed in a JAR, I get the runtime error:
java.lang.NoClassDefFoundError: org/eclipse/debug/core/DebugPlugin
3. ...but under the very same session the Hello World example still
works fine.
So I must have done something that causes the class loader to fail at
runtime in my plugin only... any idea what that might have been?
It loads hundreds of other classes, this is the only failure.
(thanks)
-- Michael
Re: cannot load a class at runtime / REWARD OFFERED... :) [message #235610 is a reply to message #235603] Wed, 06 September 2006 09:51 Go to previous messageGo to next message
How different is the MANIFEST of your plugin from your helloworld plugin?
Headers I'd look at: Bundle-ClassPath and Require-Bundle
Later,
PW
Re: cannot load a class at runtime / REWARD OFFERED... :) [message #235616 is a reply to message #235610] Wed, 06 September 2006 10:04 Go to previous messageGo to next message
> Later,
> PW
Both manifests include the dependency on org.eclipse.debug.core (which
is the only reason I can compile in both cases). My plugin has a
dependency on another of my plugins (com.mka.core, listed last).
Here are both manifests:
HELLO WORLD MANIFEST.MF
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Launcher Plug-in
Bundle-SymbolicName: com.mka.launcher; singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: com.mka.launcher.Activator
Bundle-Vendor: MKA
Bundle-Localization: plugin
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
Eclipse-LazyStart: true
Bundle-Name: Editors Plug-in
Bundle-SymbolicName: com.mka.ui.editors; singleton:=true
Bundle-Activator: com.mka.ui.editors.EditorsPlugin
Bundle-Vendor: MKA
Require-Bundle: org.eclipse.ui.ide,
org.eclipse.ui,
org.eclipse.core.resources,
org.eclipse.jface,
org.eclipse.debug.core,
com.mka.core
Eclipse-BuddyPolicy: registered
Export-Package: com.mka.ui.dialogs,
com.mka.ui.editors,
com.mka.ui.editors.actions,
com.mka.ui.editors.capproject,
com.mka.ui.editors.cashflow,
com.mka.ui.editors.collateral,
com.mka.ui.editors.views,
com.mka.ui.perspectives
Re: cannot load a class at runtime / REWARD OFFERED... :) [message #235623 is a reply to message #235616] Wed, 06 September 2006 10:12 Go to previous messageGo to next message
> Bundle-Vendor: MKA
> org.eclipse.ui,
> org.eclipse.jface,
> com.mka.core
> com.mka.ui.editors,
OK, what does the manifest for com.mka.core look like?
Also, you are getting the java.lang.NoClassDefFoundError:
org/eclipse/debug/core/DebugPlugin in the error log, correct?
What are the full stack traces for the first 3 errors in your error log?
Later,
PW
Re: cannot load a class at runtime / REWARD OFFERED... :) [message #235637 is a reply to message #235623] Wed, 06 September 2006 10:41 Go to previous messageGo to next message
> Later,
> PW
MANIFEST.MF for com.mka.core
Bundle-Name: Core Plug-in
Bundle-SymbolicName: com.mka.core; singleton:=true
Bundle-Activator: com.mka.core.CorePlugin
Bundle-Vendor: MKA
org.eclipse.jdt.core,
org.eclipse.ui.ide,
org.eclipse.jdt.launching,
Eclipse-AutoStart: true
Export-Package: com.mka.core,
com.mka.core.analytics,
com.mka.core.analytics.structures,
com.mka.core.calendar,
com.mka.core.fileops,
com.mka.core.util
SECOND ERROR / STACK TRACE
Unhandled event loop exception
An exception stack trace is not available.
FIRST ERROR / STACK TRACE
com.mka.ui.editors.capproject.CapProjectPropertiesEditor.lau nchDealViewer(CapProjectPropertiesEditor.java:602)
com.mka.ui.editors.capproject.CapProjectPropertiesEditor.wid getSelected(CapProjectPropertiesEditor.java:593)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:949)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:934)
at org.eclipse.swt.widgets.Link.WM_LBUTTONUP(Link.java:786)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3280 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4023 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:18 79)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2964)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: cannot load a class at runtime / REWARD OFFERED... :) [message #235649 is a reply to message #235637] Wed, 06 September 2006 11:02 Go to previous messageGo to next message
This manifest looks fine as well.
> at
> at
There are only the 2 errors in your error log? "Unhandled event loop
exception" and the NCDFE?
Later,
PW
Re: cannot load a class at runtime / REWARD OFFERED... :) [message #235664 is a reply to message #235649] Wed, 06 September 2006 11:22 Go to previous messageGo to next message
> Later,
> PW
Yes, just those two. both are thrown by org.eclipse.ui.
Re: cannot load a class at runtime / REWARD OFFERED... :) [message #235671 is a reply to message #235616] Wed, 06 September 2006 12:02 Go to previous messageGo to next message
>> plugin?
>> Later,
>> PW
The manifest looks OK, but the build.properties might be wrong (a common
error is to forget the '.' in bin.includes) and hence the JARed plug-in
is not OK. Make sure to enable al PDE compiler detection rules and try this:
1. select your plug-in
2. PDE Tools > Organize Manifests...
3. check all options
4. press Finish
Now check whether somethings changed in your manifest or build.properties.
HTH
Dani
> Bundle-Vendor: MKA
> Bundle-Vendor: MKA
> org.eclipse.ui,
> org.eclipse.jface,
> com.mka.core
> com.mka.ui.editors,
Re: cannot load a class at runtime / REWARD OFFERED... :) [message #235677 is a reply to message #235671] Wed, 06 September 2006 13:03 Go to previous messageGo to next message
> this:
> 4. press Finish
> HTH
> Dani
that had no effect -- here are the build.properties:
build.properties for com.mka.EditorsPlugin
source.. = src/
output.. = bin/
bin.includes = plugin.xml,\
META-INF/,\
icons/
build.properties for com.mka.CorePlugin
source.. = src/
output.. = bin/
META-INF/,\
icons/
Re: cannot load a class at runtime / REWARD OFFERED... (we have 2 winners) [message #235739 is a reply to message #235677] Thu, 07 September 2006 21:33 Go to previous message
OK, here is what I did --
-- went to a different pc
-- installed a clean eclipse 3.2
-- imported my source code
-- cleaned up the build configs
-- installed another clean eclipse
-- built to that location
.. now it's OK.
(so I cause some subtle misconfiguration somewhere)
I really appreciate the help that I get from both of you --
-- write to me off list to claim your prize: michael.megliola@gmail.com
Previous Topic:debugger using old class file
Next Topic:Updating ASTNode when the AST changes
Current Time: Sun Jul 27 08:46:38 EDT 2025
Powered by FUDForum. Page generated in 0.05044 seconds
