Home » Modeling » GMF (Graphical Modeling Framework) » Use separate diagram file, or not?
Use separate diagram file, or not? [message #235307] Mon, 06 July 2009 05:03 Go to next message
Originally posted by: tobk42.gmx.de
I've started using GMF using separate files for the semantic and
notation model, which proved to be useful for re-creating the diagram
files when making changes to the diagram editor. But now that my editor
has somewhat matured, I wonder how useful the separate-files-feature
still is...
So I would like to hear your opinions: Are you using one file for both
semantic and notation model, or separate files, and for what reasons?
Tobias
Re: Use separate diagram file, or not? [message #235372 is a reply to message #235307] Mon, 06 July 2009 06:00 Go to previous message
Hello tobias,
Both cases are valid (single file for domain and diagram or two separate).
Each solution has possible drawbacks for some particular use cases. If your
project is nearly finished and you do not see any problems with domain/diagram
info separation then I suggest you to stay with this configuration - it's
always good to keed independent parts (domain info has nothing to do with
diagram) separated.
Alex Shatalin
Previous Topic:New Project Action
Next Topic:Top Nodes with same class Element - no display at the creation
Current Time: Sat Jul 26 04:30:03 EDT 2025
Powered by FUDForum. Page generated in 0.26520 seconds
