Home » Language IDEs » AspectJ » Debugging AspectJ Compiled Code
Debugging AspectJ Compiled Code [message #23021] Wed, 04 June 2003 15:19 Go to next message
Originally posted by: achoi.celeres.biz
Hi All,
When I attempt to debug my AspectJ woven and compiled Java code my Eclipse
IDE shows the incorrect source location of my breakpoint and code
execution.
I understand this is due to the fact that Aspect is weaving additional
code, thus my compiled classes do not match my original source (before
AOP).
I did read somewhere that if I include the "-XnoInline" Aspect compiler
option then this may help me to generate classes that will match closer to
my original source code. However, I'm using Ant 1.5.1 and I have not
found any information on how to code this Aspect compiler option for the
<iajc> tag in my build.xml Ant script.
I'm hoping that I would not have to resort to using Sytem.out or a Logging
API to help me to debug my AOP code.
As a bigger question how are Aspect Technology implementors and
Programmers addressing this debugging issue?
Thanks.
Re: Debugging AspectJ Compiled Code [message #23064 is a reply to message #23021] Wed, 04 June 2003 17:10 Go to previous messageGo to next message
Hi Alex,
Have you seen what the AJDT FAQ says about debugging AspectJ programs from
within Eclipse ?
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/org.ecli pse.ajdt/faq.html?rev=1.2&content-
type=text/html&cvsroot=Technology_Project#q:debug
With regards to passing the noInline option to the iajc ant task, there is
some information on setting -X options in chapter 2 (AspectJ Ant Tasks) of
the Development Guide that ships with the latest AspectJ release.
George
On Wed, 4 Jun 2003 19:19:56 +0000 (UTC), Alex Choi <achoi@celeres.biz>
wrote:
> Hi All,
> Eclipse
> execution.
> AOP).
> to
> Logging
> Thanks.
George
Re: Debugging AspectJ Compiled Code [message #23187 is a reply to message #23064] Thu, 05 June 2003 14:54 Go to previous messageGo to next message
Hi George,
Thank you for your helpful reply.
I checked out link that you mentioned and the AspectJ Ant Tasks. I found
the AspectJ Ant Tasks documentation in the AspectJ 1.0.6 bundled. I read
somewhere that the AspectJ docs are not bundled with the current 1.1.2
release.
I found out to pass the -XnoInline AspectJ compiler option through Ant is
by the X=\"<option 1>,<option 2>,...\" attribute in the <iajc> tag. I
hope this helps anyone else who may have the same question.
I proceeded with building, and deploying my J2EE application with the
applied (generated) Aspect code. I used the -XnoInline option to allow
me to debug my code. But when I debug my code I see that Eclipse (my
version is 2.1) is not stepping through my source correctly. At this
point I\'m thinking that the -XnoInline option is not working. As a
double-check I decompile my class that I want to debug twice, one without
and with the -XnoInline. In both cases the decompile code is the same.
So it looks like this no line Aspect compiler option does not work (for me
at least). In the past I can use Eclipe to debug non-Aspect Oriented code
running in the Servlet and EJB container without problems. Maybe there is
something else I set somewhere.
I hope someelse may have any other suggestions.
Thanks everyone.
George Harley wrote:
> Hi Alex,
> within Eclipse ?
> Best regards,
> George
> wrote:
> > Hi All,
> > Eclipse
> > execution.
> > AOP).
> > I did read somewhere that if I include the \"-XnoInline\" Aspect compiler
> > to
> > my original source code. However, I\'m using Ant 1.5.1 and I have not
> > I\'m hoping that I would not have to resort to using Sytem.out or a
> > Logging
> > Thanks.
> George
Re: Debugging AspectJ Compiled Code [message #23220 is a reply to message #23187] Thu, 05 June 2003 15:10 Go to previous messageGo to next message
I like to add another comment. I understand that when the future version
of Eclipse implements JSR-45 then this will resolve my issue and every
AspectJ Programmer. In the meantime is there way to use Eclipse or any
other easy to use visual source Java debugger tool to debug an Aspect Java
code?
Thanks.
Alex choi wrote:
> Hi George,
> release.
> Thanks everyone.
> > Hi Alex,
> > within Eclipse ?
> > Best regards,
> > George
> > wrote:
> > > Hi All,
> > > Eclipse
> > > execution.
> > > AOP).
> > > to
> > > Logging
> > > Thanks.
> > George
Re: Debugging AspectJ Compiled Code [message #23263 is a reply to message #23220] Thu, 05 June 2003 19:36 Go to previous messageGo to next message
Debugging Aspect code using Eclipse works for me!
I placed the <iajc> X option in the correct location. I can use Eclipse
IDE to trace through my code. There is a minor annoyance that the Eclipse
debugger jumps around a few lines (depending on the size of the woven
Aspect code) when an Aspect code is being trace through. Eclipse is sync
with your source once it hits your code again.
Thanks you for your help.
> code?
> Thanks.
> Alex choi wrote:
> > Hi George,
> > release.
> > Thanks everyone.
> > > Hi Alex,
from
> > > within Eclipse ?
is
of
> > > Best regards,
> > > George
> > > wrote:
> > > > Hi All,
> > > > Eclipse
> > > > execution.
> > > > AOP).
compiler
closer
> > > > to
the
> > > > Logging
> > > > Thanks.
> > > George
Re: Debugging AspectJ Compiled Code [message #23985 is a reply to message #23263] Mon, 23 June 2003 11:15 Go to previous message
Originally posted by: skadam.us.nomura.com
Alex,
I am trying to use aspect in my EJB and Servlet, I don't even see my
aspect getting executed.
Can you please tell me what i have to do in term of the App Server.
I have included the .class generated from Aspect in my .ear file and
running
the app server with aspectjrt.jar in the classpath too.
Sal
Re: Debugging AspectJ Compiled Code [message #568166 is a reply to message #23021] Wed, 04 June 2003 17:10 Go to previous message
Hi Alex,
within Eclipse ?
George
wrote:
> Hi All,
> Eclipse
> execution.
> AOP).
> to
> Logging
> Thanks.
George
Re: Debugging AspectJ Compiled Code [message #568335 is a reply to message #23064] Thu, 05 June 2003 14:54 Go to previous message
Hi George,
release.
Thanks everyone.
> Hi Alex,
> within Eclipse ?
> Best regards,
> George
> wrote:
> > Hi All,
> > Eclipse
> > execution.
> > AOP).
> > to
> > Logging
> > Thanks.
> George
Re: Debugging AspectJ Compiled Code [message #568377 is a reply to message #23187] Thu, 05 June 2003 15:10 Go to previous message
code?
Thanks.
Alex choi wrote:
> Hi George,
> release.
> Thanks everyone.
> > Hi Alex,
> > within Eclipse ?
> > Best regards,
> > George
> > wrote:
> > > Hi All,
> > > Eclipse
> > > execution.
> > > AOP).
> > > to
> > > Logging
> > > Thanks.
> > George
Re: Debugging AspectJ Compiled Code [message #568444 is a reply to message #23220] Thu, 05 June 2003 19:36 Go to previous message
> code?
> Thanks.
> Alex choi wrote:
> > Hi George,
> > release.
> > Thanks everyone.
> > > Hi Alex,
from
> > > within Eclipse ?
is
of
> > > Best regards,
> > > George
> > > wrote:
> > > > Hi All,
> > > > Eclipse
> > > > execution.
> > > > AOP).
compiler
closer
> > > > to
the
> > > > Logging
> > > > Thanks.
> > > George
Re: Debugging AspectJ Compiled Code [message #569226 is a reply to message #23263] Mon, 23 June 2003 11:15 Go to previous message
Alex,
running
Sal
Previous Topic:1.1.3 installation broken on linux
Next Topic:Newbie Eclipse AJDT Install Question
Current Time: Sat Aug 30 19:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.05920 seconds
