Home » Eclipse Projects » GEF » Does ScaledGraphics implement setBackgroundPattern() in 3.3?
Does ScaledGraphics implement setBackgroundPattern() in 3.3? [message #235048] Mon, 04 June 2007 15:36 Go to next message
Originally posted by: mlevison.gmail.com
I'm trying to use the setBackgroundPattern() to achieve a diagonal
linear gradient fill. So far so good. At normal resolutions this works
in 3.2 - but if I attempt to zoom or print I get an exception and
discover that ScaledGraphics (and therefore PrinterGraphics) have not
implemented it.
Has this been implemented in 3.3 or should I file a bug?
Cheers
Mark Levison
Most recent posts:
Eclipse/GEF More questions that answers
http://www.notesfromatooluser.com/2007/06/eclipsegef_more.ht ml
12 Easy steps for generating Index Cards from your Sprint Backlog
http://www.notesfromatooluser.com/2007/06/12_easy_steps_f.ht ml
Scrum in a Nutshell Presentation
http://www.notesfromatooluser.com/2007/05/scrum_in_a_nuts.ht ml
Re: Does ScaledGraphics implement setBackgroundPattern() in 3.3? [message #235117 is a reply to message #235048] Tue, 05 June 2007 19:09 Go to previous messageGo to next message
Hi Mark,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132361
Cheers...
Anthony
"Mark Levison" <mlevison@gmail.com> wrote in message
news:f41pkk$vun$1@build.eclipse.org...
> I'm trying to use the setBackgroundPattern() to achieve a diagonal linear
> gradient fill. So far so good. At normal resolutions this works in 3.2 -
> but if I attempt to zoom or print I get an exception and discover that
> ScaledGraphics (and therefore PrinterGraphics) have not implemented it.
> Cheers
> Mark Levison
> Most recent posts:
Re: Does ScaledGraphics implement setBackgroundPattern() in 3.3? [message #235131 is a reply to message #235117] Tue, 05 June 2007 19:49 Go to previous message
Anthony Hunter wrote:
> Hi Mark,
Thanks for the bug - sad that its not fixed. I will come with a solution
sometime soon.
Cheers
Mark Levison
Previous Topic:PlaceHolderModel in ediagram example
Next Topic:deployment descriptor user-interface for web.xml
Current Time: Fri Jul 18 02:00:43 EDT 2025
Powered by FUDForum. Page generated in 0.07944 seconds
