Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Hello XML World Example error
Re: [buckminster-dev] Hello XML World Example error [message #22975] Tue, 22 July 2008 14:53
Originally posted by: mojo.sebald.t-online.de
Hi Thomas,
>The error stems from a DateFormat being unable to parse the date. It
>works fine on the platforms where I've tried it. That's why I'm
>interested in what Java VM you are using.
sorry I forgot to mention my Java Version:
I use Java SE 6 (jre1.6.0_06)
and startup Eclipse with the vm commandline option:
C:\Programme\Eclipse\eclipse_3_4\eclipse.exe -vm
"C:\Programme\Java\jre1.6.0_06\bin\javaw.exe"
to be sure this version is used.
Best Regards
Johannes Sebald
View this message in context: http://www.nabble.com/Hello-XML-World-Example-error-tp185569 79p18595858.html
Sent from the Eclipse - Buckminster Dev mailing list archive at Nabble.com.
Previous Topic:Non Java projects Proposal
Next Topic:[buckminster-dev] +1 for Adrian Skehill
Current Time: Fri Jul 18 23:33:10 EDT 2025
Powered by FUDForum. Page generated in 0.04982 seconds
