how to set the (win32) PATH in debug configuration? [message #234352] |
Fri, 29 May 2009 05:49 |
Hello cdt-Group,
I have the problem to debug a C++ Program which uses a PostgresQL-DLL.
Environment:
WinXP Prof SP3 32bit
eclipse Ganymede 3.4.2
cdt 5.0.2
MinGW 5.1.4 / MSys 1.0
When I start debugging, I become an Error Dialog titled "MinGW gdb
Debugger", Message "Execution is suspended because of error", Detail
"You can't do that without a process to debug". I have discovered
that the program can't find the lippq.dll; when i set the path to
the dll in system environment, the debugger runs.
For run configuration I only have to set the PATH in
Launch Configuration -> TAB Environment ->
Variable "PATH"; Value "${workspace_loc}\project\win32\dll
and it runs.
But this value isn't evaluated when starting the debugger, as one
can see when printf'ing the result of getenv("PATH") on console:
+ run without debugger: "PATH=C:\cework\project\win32\dll"
- with debugger: "PATH=C:\java\...;C:\WINDOWS\system32;..."
In other words: after start with debugger the path is set to the
normal windows system path, only prefixed with java bin directories,
but *not* with replacement with the Valie of the PATH Variable in
the Launch Configuration.
Is this a known behavior (i haven't found in bugzilla)?
Do you know how it can be fixed without the workaround to set the
PATH in System or .bat-File before starting eclipse?
Thanks in advance,
Detlef
FUDForum. Page generated in 0.06198 seconds
