Re: Problem opening ecore_diagram file/dynamic diagram generation [message #234335] |
Sat, 20 June 2009 05:21 |
Max,
This sounds like a GMF question, so best to ask there. I've added that
newsgroup to the "to" list of the reply, so no need to repost.
Max Shell wrote:
> Greetings, i'm creating an eclipse plugin, it has a view that make some
> calculations and then create a diagram that is displayed on the editor, my
> actual solution is that the view creates an .ecore and an ecore_diagram file
> using dom, save them locally and then calls the editor (very ugly), the
> problem is that I cant open the ecore_diagram because the file do not
> belongs to any project.
> As far as I know eclipse is not able (at the moment) to open diagram files
> outside the workspace as is described on this thread:
> http://dev.eclipse.org/newslists/news.eclipse.modeling.mdt.u ml2tools/msg00724.html
> (my plugin doesn't use any project or workspace files, the data is passed
> directly inside the view)
> So i made a temporary solution, is to take any project using
> ResourcesPlugin.getWorkspace().getRoot().getProjects()[0] and create
> temporary links by file.createLink and then load the diagram (very ugly too)
> It would be nice to get rid of the serialized models, I just don't need
> them, so my questions are:
> - How can i extend the editor and set by myself the correct iPath ,
> IEditorinput or something else to make it able to open the ecore_diagram?
> - Or how can i extend the ecore diagram editor to directly create the
> model -> diagram and display it?
> - there is another way to get a solution?
> Sorry for my long post, I hope that I'm asking on the right thread and
> thanks in advance
> Max Shell
FUDForum. Page generated in 0.03346 seconds
