Home » Eclipse Projects » JFace » [databinding] ControlDecorationSupport idea
[databinding] ControlDecorationSupport idea [message #22945] Wed, 22 July 2009 15:31 Go to next message
I'm experimenting with ControlDecorationSupport and it is quite handy! I
created a custom ControlDecorationUpdater because I wanted the feature for
required fields that:
- uses "FieldDecorationRegistry.DEC_REQUIRED" the first time
- uses "FieldDecorationRegistry.DEC_ERROR" if the status goes ok and then
back to error
This is a good practice for wizards, etc so users doesn't see a glaring red
X before they even have a chance to provide a value. To do this, I had to
override update() instead of getImage() because I needed access to the
decoration.
new ControlDecorationUpdater() {
protected void update(ControlDecoration decoration,
IStatus status) {
if (status == null || status.isOK()) {
decoration.hide();
} else {
if (decoration.getImage() == null
&& status instanceof RequiredStatus)
{ // my custom error IStatus
decoration
.setImage(FieldDecorationRegistry
.getDefault()
.getFieldDecoration(
FieldDecorationRegistry.DEC_REQUIRED).getImage());
} else {
decoration.setImage(getImage(status));
decoration
.setDescriptionText(getDescriptionText(status));
decoration.show();
I'm mentioning this as a use case to provide feedback. Has anyone else done
something similar? Would this concept be useful to add to the framework
level (maybe through other means)?
-Will
Re: [databinding] ControlDecorationSupport idea [message #23319 is a reply to message #22945] Wed, 22 July 2009 17:52 Go to previous messageGo to next message
> I created a custom ControlDecorationUpdater because I wanted the feature
> for required fields that:
> then back to error
I am with you Will. That really bugs me with Databinding too. You always
get to see the "X" error decoration before the user can enter a value.
All fields that require User input should marked as required first and
only after the user changed the control the marker should turn to error
or warning.
I filed a question about how to achieve that with databinding a few days
ago her in the group but the response was not satisfying.
Maybe you have more luck and post your results here.
Phil
Re: [databinding] ControlDecorationSupport idea [message #23450 is a reply to message #23319] Thu, 23 July 2009 02:48 Go to previous messageGo to next message
I was pretty confused by your question, and wasn't really sure if I knew
what you were asking for. If you were asking about
ControlDecorationSupport, I can imagine my response was not that helpful.
Would you file a bug report in bugzilla for this? This behavior is
probably expected under the Eclipse UI guidelines anyway.
Matthew
Re: [databinding] ControlDecorationSupport idea [message #23492 is a reply to message #23450] Thu, 23 July 2009 04:49 Go to previous messageGo to next message
>> days ago her in the group but the response was not satisfying.
> Matthew
I am sorry if it was not clear in my question back then. The issue was,
that the user should not be hit by validation before he had a chance to
enter some data. And that means that he must have a chance to enter some
data into each field of a DataBindingContext before the the validator
turns from "required" to "error".
I have filee a bugreport and made screenshots.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284384
Phil
Re: [databinding] ControlDecorationSupport idea [message #23535 is a reply to message #22945] Thu, 23 July 2009 04:50 Go to previous message
> then back to error
I filed a bug report for that under
Previous Topic:MultiValidator disposal
Next Topic:[databinding] ControlDecorationSupport feedback: provide access to the ControlDecoration
Current Time: Thu May 08 01:07:35 EDT 2025
Powered by FUDForum. Page generated in 0.04301 seconds
