Home » Eclipse Projects » Eclipse Platform » How to use org.eclipse.update.ui.forms??
How to use org.eclipse.update.ui.forms?? [message #234324] Mon, 26 April 2004 03:58 Go to next message
Originally posted by: purjo76.luukku.com
Hi!
IŽm using Eclipse 2.1.2 and I would like to do same kind of editor that is
used i.e. for editing plugin.xml file in Eclipse. After looking the source
code of Eclipse I found out that they are using the package
'org.eclipse.update.ui.forms' for creating the editors. Anyway, I could
not find any instructions of how to use this package? Where could I find
API of it; for some reason it is not included in Eclipses API?? I also
searched this Eclipse site for 'org.eclipse.update.ui.forms', but did not
get any hits at all!!
Or is there some other way to create editors with this flat look??
Re: How to use org.eclipse.update.ui.forms?? [message #234389 is a reply to message #234324] Mon, 26 April 2004 06:58 Go to previous messageGo to next message
Originally posted by: dirk.meister.web.de
the eclipse forms API is available since Eclipse 3.0, but not in Eclipse
2.1
Any way there is an eclipse article which explains the use of the api.
Link:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/pde-ui-h ome/working/EclipseForms/EclipseForms.html
Greeting
Dirk
Purjo wrote:
> Hi!
Re: How to use org.eclipse.update.ui.forms?? [message #234396 is a reply to message #234389] Mon, 26 April 2004 07:22 Go to previous messageGo to next message
But the flat look is already used in many "native" editors found from
Eclipse 2.1?? Is it really impossible to use it with own Eclipse plugins
on 2.1??
Dirk Meister wrote:
> 2.1
> Link:
> Greeting
> Dirk
> Purjo wrote:
> > Hi!
Re: How to use org.eclipse.update.ui.forms?? [message #234402 is a reply to message #234389] Mon, 26 April 2004 07:22 Go to previous messageGo to next message
on 2.1??
Dirk Meister wrote:
> 2.1
> Link:
> Greeting
> Dirk
> Purjo wrote:
> > Hi!
Re: How to use org.eclipse.update.ui.forms?? [message #234408 is a reply to message #234402] Mon, 26 April 2004 07:36 Go to previous messageGo to next message
Originally posted by: dmeister.upb.de
No, it is not impossible. But the flat forms API is internal code of the
PDE plugins.
Controls like Buttons have a style SWT.FLAT which produces a button with
the flat look of the "plugin editor" or "feature editor".
So you can emulate the view but the special forms SWT layouter is in 2.1
not available to public, as far as i know.
The problem with e.g. GridLayout is that the normal layouter are not
scrollable. In an no-scrollable editor the sub element will be hidden,
when the editor area is to small.
Other advantages of the api are explaint in the article linked in the
last message.
It is possible in 2.1 but it not as easy and good as in 3.0 with the
public eclipse flat forms api.
> on 2.1??
> Dirk Meister wrote:
>>Hi,
>> 2.1
>>Link:
>>Greeting
>>Dirk
>>Purjo wrote:
>>>Hi!
Re: How to use org.eclipse.update.ui.forms?? [message #234415 is a reply to message #234408] Mon, 26 April 2004 07:43 Go to previous messageGo to next message
Thanks for this information!
I know that SWT.FLAT option, but it seemed not to work i.e. for Composite
used on the background. I could not find API or any other documents for
Eclipse 2.1Žs forms, and itŽs pretty hard to code without any references...
> PDE plugins.
> last message.
> > on 2.1??
> > Dirk Meister wrote:
> >>Hi,
> >> 2.1
> >>Link:
> >>Greeting
> >>Dirk
> >>Purjo wrote:
> >>>Hi!
Re: How to use org.eclipse.update.ui.forms?? [message #234460 is a reply to message #234415] Mon, 26 April 2004 09:19 Go to previous message
So can you tell me how to get that flat look for the editorŽs
background...?
> > PDE plugins.
> > last message.
> > > on 2.1??
> > > Dirk Meister wrote:
> > >>Hi,
> > >> 2.1
> > >>Link:
> > >>Greeting
> > >>Dirk
> > >>Purjo wrote:
> > >>>Hi!
is
source
not
Previous Topic:Plug in for LaTeX
Next Topic:Eclipse does not start
Current Time: Mon Jul 07 20:38:43 EDT 2025
Powered by FUDForum. Page generated in 0.04697 seconds
