Home » Modeling » GMF (Graphical Modeling Framework) » Problem opening ecore_diagram file/dynamic diagram generation
Problem opening ecore_diagram file/dynamic diagram generation [message #234309] Fri, 19 June 2009 13:55 Go to next message
Originally posted by: watertext.hotmail.it
Greetings, i'm creating an eclipse plugin, it has a view that make some
calculations and then create a diagram that is displayed on the editor, my
actual solution is that the view creates an .ecore and an ecore_diagram file
using dom, save them locally and then calls the editor (very ugly), the
problem is that I cant open the ecore_diagram because the file do not
belongs to any project.
As far as I know eclipse is not able (at the moment) to open diagram files
outside the workspace as is described on this thread:
http://dev.eclipse.org/newslists/news.eclipse.modeling.mdt.u ml2tools/msg00724.html
(my plugin doesn't use any project or workspace files, the data is passed
directly inside the view)
So i made a temporary solution, is to take any project using
ResourcesPlugin.getWorkspace().getRoot().getProjects()[0] and create
temporary links by file.createLink and then load the diagram (very ugly too)
It would be nice to get rid of the serialized models, I just don't need
them, so my questions are:
- How can i extend the editor and set by myself the correct iPath ,
IEditorinput or something else to make it able to open the ecore_diagram?
- Or how can i extend the ecore diagram editor to directly create the
model -> diagram and display it?
- there is another way to get a solution?
Sorry for my long post, I hope that I'm asking on the right thread and
thanks in advance
Max Shell
Re: Problem opening ecore_diagram file/dynamic diagram generation [message #234340 is a reply to message #234309] Sat, 20 June 2009 05:22 Go to previous messageGo to next message
Max,
Please avoid posting the same question to multiple groups.
> thanks in advance
> Max Shell
Re: Problem opening ecore_diagram file/dynamic diagram generation [message #234428 is a reply to message #234309] Mon, 22 June 2009 07:00 Go to previous message
Hello Max,
I suggest you to try using URIEditorInput for all the models. In this case
you can even handle EMF resources creation by your own factory (load data
from any other sources but the XMI files).
BTW, in case you are creating diagram/model files I suggest you using EMF-generated
API for domain model and Notation Model API for diagram one - this will simplify
diagram structure creation.
Alex Shatalin
Previous Topic:Copy & Paste, CopyPaste, Duplication
Next Topic:Xtext and EMF Model Editor
Current Time: Tue Jul 22 09:04:17 EDT 2025
Powered by FUDForum. Page generated in 0.24242 seconds
