Home » Eclipse Projects » Eclipse Platform » getDefault() returns null
getDefault() returns null [message #234147] Sun, 25 April 2004 13:38 Go to next message
Originally posted by: dwojtas.myrealbox.com
I havewritten a simple plugin with single preference page.
It is based on some samples found in the net.
This preference page makes use of the plugin.
Eg.
MyPlugin.getDefault().getPreferenceStore()
My preference page shows in the Window/Preferences menu,
but when I click in the pages tree to see my preference page I gen NPE
from getDefault()
What is the lifecycle of the plugin, when does it start?
How to make sure that my plugin started when I eter it's preference
page in configuration?
Darek
Re: getDefault() returns null [message #234217 is a reply to message #234147] Sun, 25 April 2004 17:14 Go to previous messageGo to next message
Originally posted by: Bill.Blalock.certegy.com
The RCP Tutorial Part 2 describes the lifecycle of a plugin and digs into
the WorkbenchAdvisor class. That might help you. The url is
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -ui-home/rcp-proposal/rcp_tutorial/tutorial2.html
Bill
Darek wrote:
> Eg.
> from getDefault()
> Darek
Re: getDefault() returns null [message #234338 is a reply to message #234147] Mon, 26 April 2004 04:33 Go to previous messageGo to next message
Originally posted by: ....test.com
I recently had the same effect while porting my plugins to Eclipse 3.0. With
this release, a plugin needs a default constructor under the condintions
listed in the 3.0 porting guide:
"Note also that if you mark you plug-in as 3.0 (using <?eclipse...?>) and
your plug-in defines a Plugin class, you must either explicitly <import
plugin="org.eclipse.core.runtime.compatibility"/> in the plug-in manifest or
ensure that the Plugin class defines the default constructor."
Disregarding this hint could cause the mentioned effect as the plugin
doesn't get instantiated.
Christian
"Darek" <dwojtas@myrealbox.com> wrote in message
news:rstn801hkpv54jp9fijotoag2rbkhn2tve@4ax.com...
> Eg.
> from getDefault()
> Darek
Re: getDefault() returns null [message #234766 is a reply to message #234338] Mon, 26 April 2004 16:02 Go to previous message
Thanks Christian!
That was it. Now it seems to work.
I added default, no arg constructor.
Do you know when exactly a call to
causes instantiation of the plugin?
What if at some point (but from some class within the plugin)
I call MyPlugin.getDefault() for the 1st time?
How does it know that it should initialize it before the 1st call?
Or maybe it can happen that it will not initialize before?
Darek
On Mon, 26 Apr 2004 10:33:07 +0200, "Christian Georgi" <...@test.com>
>Christian
>> Eg.
>> from getDefault()
>> Darek
Previous Topic:Update Manager through proxy with authentication
Next Topic:Updating the column headers of a view on change of selection
Current Time: Tue Aug 26 14:49:00 EDT 2025
Powered by FUDForum. Page generated in 0.04424 seconds
