Home » Modeling » OCL » accessing dynamic eobject api + function libraries
accessing dynamic eobject api + function libraries [message #22906] |
Thu, 10 May 2007 13:27  |
i would like to be able to check whether an attribute is actually set or
not within an expression, and unset it if necessary within an ocl
expression.
how can i call the eobject dynamic methods such as eIsSet(x),
isUnsettable(x) unset(x) etc within an OCL expression?
thanks in advance,
kagan
Re: accessing dynamic eobject api + function libraries [message #23880 is a reply to message #23670] |
Thu, 17 May 2007 09:10   |
Hi, Antonio,
You can take this one step further by not actually implementing the
modelClass property in your Ecore model (which might be seen as breaking
the model's semantic cohesion, especially as it crosses meta-levels), but
rather defining it in a custom Ecore environment as an OCL-defined
"additional attribute", for use by OCL constraints only.
See the newly-added Programmer's Guide topic in the M7 build, that discusses
how to extend the environment for this kind of situation, with a working
example. The example defines an additional operation, but the mechanism is
the same:
OCL Developer Guide
Programmer's Guide
Advanced Topics
Customizing the Environment
The example adds a regexMatch() operation to the String primitive type. It
is actually implemented in the
org.eclipse.ocl.ecore.tests.EcoreEnvironmentTest class, verbatim from the
guide.
Christian
Antonio Carrasco wrote:
> You may try implementing a property (added to your .ecore before
> generation),
> returning the instance of the ecore:EClass metaclass,
> then you can reason over it with OCL.
> Youll need to add the ecore metamodel Ecore.ecore
> as a resource to your own .ecore metamodel.
> For any side effects, you may just invoke any method of your own
> implementation.
> Thats breaking the rules, right.
> Thats why we put them there, first!
> <eClassifiers xsi:type="ecore:EClass" name="ConModelClass"
> abstract="true">
> <eStructuralFeatures xsi:type="ecore:EReference" name="modelClass"
> lowerBound="1" eType="ecore:EClass
> ../../../plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//EC lass "
> changeable="false" volatile="true" transient="true" derived="true"/>
> </eClassifiers>
> From the OCL console:
> Evaluating:
> self.modelClass
> Results:
> EClass Proceso
> Evaluating:
> self.modelClass.eAllAttributes
> Results:
> EAttribute codigoYNombre
> EAttribute codigo
> EAttribute nombre
> EAttribute codigoCompleto
<snip>
oclType, Re: accessing dynamic eobject api + function libraries [message #43504 is a reply to message #22950] |
Sun, 18 November 2007 06:28   |
Hi, Christian.
Is oclType now accessible in the newest version of the ocl.ecore,
or do I need to add it by hand to the environment?
I came to the problem trying to access eContainer, an Issue I will
describe in a separate post.
Best, Philipp
Christian W. Damus wrote 10.05.2007:
> Hi, Kagan,
> In any case, you should never be able to call eUnset() because OCL is a
> side-effect-free language. Its semantics do not allow the modification of
> the model that it is constraining/querying.
> Regarding eIsSet() and isUnsettable(): OCL provides no means to access the
> metamodel of the model that it is constraining. That is, you can check
> whether
> self.oclIsKindOf(Xyz)
> but you cannot do
> self.oclType
> to get the Xyz metaclass in order then to do
> self.oclType.getEStructuralFeature("x")
> I don't know whether this is an accidental or intentional omission from the
> spec. I suspect that it is accidental because the UML 2.1 specification
> actually uses such non-existent constructs as "self.oclType" in defining
> its constraints.
> Cheers,
> Christian
>> expression.
>> thanks in advance,
>> kagan
Re: oclType, Re: accessing dynamic eobject api + function libraries [message #43598 is a reply to message #43504] |
Mon, 19 November 2007 08:13  |
Hi, Philipp,
Nope, oclType isn't available yet, and probably won't be until the OMG
defines it.
Of course, one could consider, in the mean-time, sneaking it in via a new
ProblemOption (error by default) for those clients that don't mind
depending on non-standard constructs. The problem with that, though, is
that probably the OMG would end up defining something different, which
makes for an incompatible transition for these clients, anyway.
Christian
Philipp W. Kutter wrote:
> Hi, Christian.
> Best, Philipp
-----8<-----
Current Time: Sat May 10 12:10:52 EDT 2025
Powered by FUDForum. Page generated in 0.04841 seconds
