Home » Language IDEs » ServerTools (WTP) » Strange Launcher Behavior
Strange Launcher Behavior [message #233679] Tue, 14 July 2009 22:38
I don't know where to go with this, it seems like it might be a bug but I
can't even understand what I'm seeing, so maybe someone can help me
explain that first.
I have a web application which I launch in development in Tomcat from
Eclipse using the wtp system.
Until recently I always launched it from the server tab by selecting the
server and pressing the start button. This always worked without problem.
Then I decided to persist the configuration using the Common tab of the
Run->Run Configurations menu.
The two launches should be identical since they come from the same root
but they aren't. Only the persisted launch script now works (as the start
button worked before). Open or click on launch script - then Run ->
Tomcat v 6.0 Server at localhost. The old method of clicking the start
button from the Servers window fails soon after it launches with
ClassLoader errors. In my logging right before it fails, I also see
unfamiliar things. In the log4j log entries, the part that shows the name
of the Thread now shows
[ContainerBackgroundProcessor[StandardEngine[Catalina]]] which is
something I've not seen before. In the working version, the same log
entries show [main] as the thread.
How could saving a launch configuration to a .launch file corrupt the
original launch configuration and what might be happening here? Any ideas
on how to fix it?
Platform JDK 1.6 Running on Ubuntu 9.04 in Eclipse Galileo.
Thanks in advance
Previous Topic:Glassfishv3 Startup Failure
Next Topic:Elipse WTP OC4J Redeployment Problem i.e Unable to find/read file META-INF/appli
Current Time: Tue Jul 22 12:10:25 EDT 2025
Powered by FUDForum. Page generated in 0.02901 seconds
