Home » Archived » XML Schema Definition (XSD) » Generated Namespace Prexfix xmlns:Q1: How come?
Generated Namespace Prexfix xmlns:Q1: How come? [message #22851] |
Mon, 19 May 2003 13:51  |
Originally posted by: dirk.schesmer.divos.de
Hi there,
whenever I add an element reference to the method generating my schema (see
code below), the system automatically adds the namespace prefix
xmlns:Q1="..." to the schema it generates. How come? (I can get rid of it
when specifying a default namespace, but that's not want I want to...)
Thanks for help,
Dirk
(Example it an excerpt from library.xsd taken from the very good O'Reillly
book XMLSchema, author: E. van der Vlist)
public XSDSchema initializeSD3Schema() throws Exception {
XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
xsdSchema.setSchemaForSchemaQNamePrefix("xsd");
xsdSchema.setTargetNamespace("http://www.divos.de/sd3.xsd");
Map qNamePrefixToNamespaceMap =
xsdSchema.getQNamePrefixToNamespaceMap();
qNamePrefixToNamespaceMap.put(
xsdSchema.getSchemaForSchemaQNamePrefix(),
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
XSDFactory xsdFactory = XSDSchemaBuildingTools.getXSDFactory();
String targetNamespace = xsdSchema.getTargetNamespace();
XSDElementDeclaration elementDecl = null;
elementDecl =
xsdSchema.resolveElementDeclaration(targetNamespace, "name");
XSDTypeDefinition typeDef =
xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition(
"string");
elementDecl.setTypeDefinition(typeDef);
xsdSchema.getContents().add(elementDecl);
elementDecl =
xsdSchema.resolveElementDeclaration(targetNamespace, "isbn");
typeDef =
"string");
elementDecl =
xsdSchema.resolveElementDeclaration(targetNamespace, "author");
XSDComplexTypeDefinition anonymousComplexTypeDefinition =
xsdFactory.createXSDComplexTypeDefinition();
XSDModelGroup anonymousComplexTypeDefinitionSequence =
xsdFactory.createXSDModelGroup();
anonymousComplexTypeDefinitionSequence.setCompositor(
XSDCompositor.SEQUENCE_LITERAL);
XSDParticle anonymousTypeDefinitionParticle =
xsdFactory.createXSDParticle();
anonymousTypeDefinitionParticle.setContent(
anonymousComplexTypeDefinitionSequence);
XSDElementDeclaration nameRef =
xsdFactory.createXSDElementDeclaration();
nameRef.setResolvedElementDeclaration(
xsdSchema.resolveElementDeclaration("name"));
XSDParticle nameRefParticle = xsdFactory.createXSDParticle();
nameRefParticle.setContent(nameRef);
anonymousComplexTypeDefinitionSequence.getContents().add(
nameRefParticle);
anonymousComplexTypeDefinition.setContent(
anonymousTypeDefinitionParticle);
elementDecl.setAnonymousTypeDefinition(anonymousComplexTypeD efinition);
XSDAttributeDeclaration attributeDecl =
xsdFactory.createXSDAttributeDeclaration();
attributeDecl.setName("id");
attributeDecl.setTypeDefinition(
xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition("ID "));
xsdSchema.getContents().add(attributeDecl);
return xsdSchema;
Re: Generated Namespace Prexfix xmlns:Q1: How come? [message #22894 is a reply to message #22851] |
Tue, 20 May 2003 11:40  |
--------------8193787C9112A53913FC62B0
Content-Type: text/plain; charset=us-ascii
Dirk,
In order to reference anything in any namespace, an xmlns declaration is
required for the namespace. If there isn't one already specified, one is
created on demand. If you have a particular favorite prefix you want to use,
you should set it into the prefix map beforehand, e.g., this will create a null
prefix for the schema's target namespace:
qNameToPrefixMap.put(null, targetNamespace)
"Dirk V. Schesmer" wrote:
> Hi there,
> Thanks for help,
> Dirk
> elementDecl =
> "string");
> elementDecl =
> typeDef =
> "string");
> elementDecl =
> nameRefParticle);
> return xsdSchema;
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Dirk,
<p>In order to reference anything in any namespace, an xmlns declaration
is required for the namespace. If there isn't one already specified,
one is created on demand. If you have a particular favorite prefix
you want to use, you should set it into the prefix map beforehand, e.g.,
this will create a null prefix for the schema's target namespace:
<blockquote>qNameToPrefixMap.put(null, targetNamespace)</blockquote>
<p>"Dirk V. Schesmer" wrote:
<blockquote TYPE=CITE>Hi there,
<br>whenever I add an element reference to the method generating my schema
(see
<br>code below), the system automatically adds the namespace prefix
<br>xmlns:Q1="..." to the schema it generates. How come? (I can get rid
of it
<br>when specifying a default namespace, but that's not want I want to...)
<br>Thanks for help,
<p>Dirk
<p>(Example it an excerpt from library.xsd taken from the very good O'Reillly
<br>book XMLSchema, author: E. van der Vlist)
<br>public XSDSchema initializeSD3Schema() throws Exception {
<p>XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
<p>xsdSchema.setSchemaForSchemaQNamePrefix("xsd");
<p>xsdSchema.setTargetNamespace("<a href="http://www.divos.de/sd3.xsd">http://www.divos.de/sd3.xsd</a>");
<p>Map qNamePrefixToNamespaceMap =
<p>xsdSchema.getQNamePrefixToNamespaceMap();
<p>qNamePrefixToNamespaceMap.put(
<p>xsdSchema.getSchemaForSchemaQNamePrefix(),
<p>XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
<p>XSDFactory xsdFactory = XSDSchemaBuildingTools.getXSDFactory();
<p>String targetNamespace = xsdSchema.getTargetNamespace();
<p>XSDElementDeclaration elementDecl = null;
<p>elementDecl =
<p>xsdSchema.resolveElementDeclaration(targetNamespace, "name");
<p>XSDTypeDefinition typeDef =
<p>xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition(
<p>"string");
<p>elementDecl.setTypeDefinition(typeDef);
<p>xsdSchema.getContents().add(elementDecl);
<p>elementDecl =
<p>xsdSchema.resolveElementDeclaration(targetNamespace, "isbn");
<p>typeDef =
<p>"string");
<p>elementDecl =
<p>xsdSchema.resolveElementDeclaration(targetNamespace, "author");
<p>XSDComplexTypeDefinition anonymousComplexTypeDefinition =
<p>xsdFactory.createXSDComplexTypeDefinition();
<p>XSDModelGroup anonymousComplexTypeDefinitionSequence =
<p>xsdFactory.createXSDModelGroup();
<p>anonymousComplexTypeDefinitionSequence.setCompositor(
<p>XSDCompositor.SEQUENCE_LITERAL);
<p>XSDParticle anonymousTypeDefinitionParticle =
<p>xsdFactory.createXSDParticle();
<p>anonymousTypeDefinitionParticle.setContent(
<p>anonymousComplexTypeDefinitionSequence);
<p>XSDElementDeclaration nameRef =
<p>xsdFactory.createXSDElementDeclaration();
<p>nameRef.setResolvedElementDeclaration(
<p>xsdSchema.resolveElementDeclaration("name"));
<p>XSDParticle nameRefParticle = xsdFactory.createXSDParticle();
<p>nameRefParticle.setContent(nameRef);
<p>anonymousComplexTypeDefinitionSequence.getContents().add(
<p>nameRefParticle);
<p>anonymousComplexTypeDefinition.setContent(
<p>anonymousTypeDefinitionParticle);
<p> elementDecl.setAnonymousTypeDefinition(anonymousComplexTypeD efinition);
<p>XSDAttributeDeclaration attributeDecl =
<p>xsdFactory.createXSDAttributeDeclaration();
<p>attributeDecl.setName("id");
<p>attributeDecl.setTypeDefinition(
<p>xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition( "ID"));
<p>xsdSchema.getContents().add(attributeDecl);
<p>return xsdSchema;
<p>}</blockquote>
</html>
--------------8193787C9112A53913FC62B0--
Re: Generated Namespace Prexfix xmlns:Q1: How come? [message #572267 is a reply to message #22851] |
Dirk,
> Hi there,
> Thanks for help,
> Dirk
> elementDecl =
> "string");
> elementDecl =
> typeDef =
> "string");
> elementDecl =
> nameRefParticle);
> return xsdSchema;
<html>
Dirk,
(see
of it
<p>Dirk
<p>elementDecl =
<p>"string");
<p>elementDecl =
<p>typeDef =
<p>"string");
<p>elementDecl =
<p>}</blockquote>
</html>
Current Time: Sun Aug 31 07:04:00 EDT 2025
Powered by FUDForum. Page generated in 0.03999 seconds
