Home » Language IDEs » C / C++ IDE (CDT) » MinGW does not apear in toolchain
MinGW does not apear in toolchain [message #233510] Thu, 30 April 2009 20:16 Go to next message
I have installed eclipse (C++ edition), QT4 (with MinGW) and QT eclipse
integration. MinGW does not apear in the tookchain, even though I have set
the correct path. If anyone can help me with this, I'd apperciate it.
Re: MinGW does not apear in toolchain [solved] [message #233557 is a reply to message #233510] Fri, 01 May 2009 14:36 Go to previous message
I apeares that CDT will only recognize MinGW is it's located at c:\mingw.
May I suggest to the developers that they include an option to specify the
location of a tool chain manually? Or at least fix CDT so that it uses the
path to identify it correctly.
.. Mads
Previous Topic:main
Next Topic:Eclipse on Windows Vista
Current Time: Tue Jul 22 12:06:30 EDT 2025
Powered by FUDForum. Page generated in 0.04650 seconds
