Home » Eclipse Projects » SWTBot » click on check-style button does not make it checked/unchecked
click on check-style button does not make it checked/unchecked [message #22799] Wed, 18 February 2009 09:57 Go to next message
I came across this behavior:
I used the click() method (from SWTBotButton) on a SWT.CHECK style Button.
The button did react to it and launched its action as with a real user.
But the problem is that the button kept its state (checked or unchecked),
which lead to bugs in the app.
I found I had to manually ask for a change in the state of the button.
I mean, instead of:
Button myButton = ((Button)bot.widget(myButtonMatcher, 3));
(new SWTBotButton(myButton)).click();
I had to use:
myButton.setSelection(true);
I think this is a bug (or maybe more like a leak), I can add a bugzilla
when I get some more time, I wanted to tell it before (or in case there
was an explaination to that).
I reproduced it on windows, I can't check other OS.
Re: click on check-style button does not make it checked/unchecked [message #22930 is a reply to message #22799] Wed, 18 February 2009 19:50 Go to previous message
you should not be using SWTBotButton for check box buttons. There is
special class for check boxes, SWTBotCheckBox. You can find it using
org.eclipse.swtbot.swt.finder.SWTBot.checkBox* methods.
Previous Topic:Open perspective
Next Topic:PROPERTIES OF COMPONENTS
Current Time: Mon Jul 14 00:25:24 EDT 2025
Powered by FUDForum. Page generated in 0.04037 seconds
