Home » Eclipse Projects » Plugin Development Environment (PDE) » Debugging Eclipse Application Problem: Launches repeatedly
Debugging Eclipse Application Problem: Launches repeatedly [message #22787] Thu, 18 September 2008 12:21
I'm having a problem debugging an Eclipse Application from Eclipse. When
I launch the Debug Configuration, the Eclipse Application starts up and
then stops repeatedly. It shows the splash screen and then disappears.
This is the farthest it gets before restarting:
MyDebugConfiguration [Eclipse Application]
org.eclipse.equinox.launcher.Main at localhost:2599
Thread [main] (Running)
Daemon Thread [Signal Dispatcher] (Running)
Daemon Thread [State Data Manager] (Running)
Daemon Thread [Framework Event Dispatcher] (Running)
Thread [State Saver] (Running)
Daemon Thread [Start Level Event Dispatcher] (Running)
Thread [Refresh Packages] (Running)
C:\MyApp\eclipse\jdk\jre\bin\javaw.exe (Sep 18, 2008 9:38:19 AM)
I am using Version 3.4.0 of the Eclipse SDK.
What is causing this?
Previous Topic:export wizard and team provider
Next Topic:Debugging Eclipse Application Problem: Launches repeatedly
Current Time: Tue Jul 15 08:21:28 EDT 2025
Powered by FUDForum. Page generated in 0.05450 seconds
