Home » Eclipse Projects » Plugin Development Environment (PDE) » Re: [JDT] wrong source editor opened during debugging
Re: [JDT] wrong source editor opened during debugging [message #1936] Fri, 25 April 2008 21:34 Go to next message
Cross posting to PDE in case this is a PDE issue.
Will Horn wrote:
> I realized this issue extends beyond SWT fragments. It happens when I
> debug any object in the target. To reproduce it I:
> 1) Navigate to any object in the target (using Ctrl+Shift+T, Ctrl+click,
> etc). This opens the "ClassFileEditor".
> 2) I put a breakpoint in this editor (I can see the little blue dot).
> 3) I run the application and it stops at my breakpoint. However, a new
> editor is opened, a "CompilationUnitEditor". I do not see my blue
> breakpoint dot, I do not have Ctrl+Shift+I inspection*, and in the case
> of SWT files, the wrong OS specific file is often opened (which I
> described in my first post).
> This is on 3.4 M5. I assume I just have something set up incorrectly,
> but any help would be greatly appreciated.
> -Will
> *Ctrl+Shift+I gives this error - "Unable to evaluate the selected
> expression: To perform an evaluation, an expression must be compiled in
> the context of a Java project's build path. The current execution
> context is not associated with a Java project in the workspace."
> Will Horn wrote:
>> Thanks for the response. No, I do not have any swt fragments other
>> than the win32 one selected in the plugins tab. Also, under the
>> Preferences Page for Target Platform, I verified that the target
>> environment is win32, win32, x86.
>> However, I do notice that in the Preferences Page for Target Platform,
>> under Source Code Locations, all the fragment source bundles are
>> listed. This makes sense because they are all in the target, but
>> maybe the debugger is choosing one at random?
>> -Will
>> Darin Swanson wrote:
>>> Do you have the swt linux fragment included in the plugins to launch
>>> with on the Plug-ins tab of your launch configuration?
>>> HTH
>>> Darins
>>> http://runnerwhocodes.blogspot.com
>>> "Will Horn" <will.horn@gmail.com> wrote in message
>>> news:fss3r1$d8n$1@build.eclipse.org...
>>>> I am developing on windows against a target platform that includes
>>>> the delta pack (both 3.4M5). When I open a SWT class (like Widget)
>>>> using Ctrl+Shift+T, I see the win32 version (the editor title is
>>>> Widget.class and if I link with the package explorer I see it under
>>>> the win32 fragment).
>>>> If I put a breakpoint in this editor, the debugger will stop at the
>>>> correct point. However, it will open the gtk source file which does
>>>> not correspond to the running code (the green highlight is on the
>>>> line number from the win32 source file). Additionally, the editor
>>>> title is Widget.java and it does not link to any file in my workspace.
>>>> Is this a bug? Or is there a way for me to change it?
>>>> Thanks in advance,
>>>> Will
Re: [JDT] wrong source editor opened during debugging [message #25081 is a reply to message #1936] Thu, 02 October 2008 17:28 Go to previous message
For anyone stumbling upon this later, here's a link to the bug report I
created:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247766
>> Ctrl+click, etc). This opens the "ClassFileEditor".
>> new editor is opened, a "CompilationUnitEditor". I do not see my blue
>> case of SWT files, the wrong OS specific file is often opened (which I
>> -Will
>> in the context of a Java project's build path. The current execution
>>> Platform, under Source Code Locations, all the fragment source
>>> bundles are listed. This makes sense because they are all in the
>>> target, but maybe the debugger is choosing one at random?
>>> -Will
>>>> HTH
>>>> Darins
>>>>> does not correspond to the running code (the green highlight is on
>>>>> the line number from the win32 source file). Additionally, the
>>>>> editor title is Widget.java and it does not link to any file in my
>>>>> workspace.
>>>>> Thanks in advance,
>>>>> Will
Re: [JDT] wrong source editor opened during debugging [message #582131 is a reply to message #1936] Thu, 02 October 2008 17:28 Go to previous message
created:
>> -Will
>>> -Will
>>>> HTH
>>>> Darins
>>>>> workspace.
>>>>> Thanks in advance,
>>>>> Will
Previous Topic:Implement own "Ctrl+LeftClick" feature in Editor
Next Topic:Plugin to create packages and classes
Current Time: Tue Jul 08 16:13:24 EDT 2025
Powered by FUDForum. Page generated in 0.03637 seconds
