Home » Language IDEs » AspectJ » Do your compiles just seem to finish instantly? Without building anything...
Do your compiles just seem to finish instantly? Without building anything... [message #22760] Fri, 30 May 2003 09:45
Originally posted by: clemas.uk.ibm.com
Just really an FYI - if you see that your compiles are finishing almost
instantly, i.e. the progress dialog appears and then disappears without
reporting any progress, then you could be suffering from a problem with
errors in your .lst file. Open the .lst file you are currently using and
look at the bottom of the build configuration editor window - if you see
'bad' entries, deselect them and save the lst file. You should then find
compiles work ok.
Andy.
AJDT Development
Previous Topic:static inter-type field on interface not supported
Next Topic:Do your compiles just seem to finish instantly? Without building anything...
Current Time: Sun Jun 01 03:54:25 EDT 2025
Powered by FUDForum. Page generated in 0.02470 seconds
