[ATL]Package with uri 'BPMN' not found.... [message #22748] |
Sat, 10 March 2007 07:23  |
Originally posted by: jihedt.yahoo.fr
Hi all !!
I encoutered difficulty with the new version of the ATL 2006 to open
ecore model generated with ATL. the transformation is OK ! no problem
but to see the result... i think the problem is that there is no link
between the model(ecore) and the metamodel (ecore)
So i work on
Eclipse 3.2
UML2 2.0
EMF 2.2
below what i obtain to open the file "bpmnresultout.ecore" witch the
metamodel is BPMN.ECORE:
"Package with uri 'BPMN' not found....
so some one have an idea ???
thank you in advance !!
Jihed TOUZI
-PhD candidate-
Centre de Génie Industriel
Ecole des Mines d'Albi Carmaux
Campus Jarlard Route de Teillet
81 013 Albi Cedex 09 FRANCE
Tel : 05 63 49 31 38
http://www.enstimac.fr
Re: [ATL]Package with uri 'BPMN' not found.... [message #23095 is a reply to message #23053] |
Mon, 12 March 2007 08:08   |
Originally posted by: mikael.barbero.gmail.com
In the previous version of ATL, models were not properly unloaded (from
the EMF registry but also from memory!) after a transformation. That's
why you were able to open your model using the reflective EMF editor. It
was not a feature, it was a bug ;) This bug has been removed and you
have now to use the "Register metamodel" contextual action.
However, you have to do it once for each metamodel, not for every
transformation. Do not forget to re-register it after each metamodel
modification also ;)
Mikaël
jihed Touzi a écrit :
> Marcos,
> It works !! great!!
> In the previous version of ATL it works automatically .. i don't have to
> use "register metamodel"... but now i have to do it every time i create
> a transformation ?
> Jihed
> Marcos Didonet Del Fabro a écrit :
>> To be able to open a model using the generic EMF editor, the
>> corresponding metamodel must be added into the registry.
>> To do that, you should select the corresponding metamodel in the AM3
>> or ATL views, and select "Register metamodel" in the context menu.
>> Regards,
>> Marcos.
>> jihed Touzi wrote:
>>> Hi all !!
>>> So i work on
>>> Eclipse 3.2
>>> UML2 2.0
>>> EMF 2.2
>>> Jihed TOUZI
>>> -PhD candidate-
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL]Package with uri 'BPMN' not found.... [message #23136 is a reply to message #23095] |
Mon, 12 March 2007 10:05   |
Thank you Mikael for your precisions !!
i think that's for one time ... a bug was a nice thing...because it is
normal after a transformation to see the result...:)!!
Jihed
Mikaël Barbero a écrit :
> Best regards,
> Mikaël
>> Marcos,
>> It works !! great!!
>> to use "register metamodel"... but now i have to do it every time i
>> create a transformation ?
>> Regards,
>> Jihed
>>> Hi,
>>> Regards,
>>> Marcos.
>>> jihed Touzi wrote:
>>>> Hi all !!
>>>> open ecore model generated with ATL. the transformation is OK ! no
>>>> problem but to see the result... i think the problem is that there
>>>> is no link between the model(ecore) and the metamodel (ecore)
>>>> So i work on
>>>> Eclipse 3.2
>>>> UML2 2.0
>>>> EMF 2.2
>>>> Jihed TOUZI
>>>> -PhD candidate-
Re: [ATL]Package with uri 'BPMN' not found.... [message #30354 is a reply to message #22836] |
Sat, 07 April 2007 14:21  |
I'm running into the same problem as Timo and I just can't find the
"Register metamodel" anywhere. I know this is really stupid but any help
would be greatly appreciated.
I'm using:
- Eclipse 3.2.2
- EMF 2.2.2
I'm using the following plugins:
AM3 - am3-20060117.zip :
org.eclipse.emf (2.2.2.v200702131851) "Eclipse Modeling Framework (EMF)"
org.eclipse.am3.core (1.0.0) "AM3 Core Plug-in" [Active]
org.eclipse.am3.tools.tge (1.0.0) "AM3 - Textual Generic Editor Plug-in"
[Active]
org.eclipse.am3.ui (1.0.0) "AM3 Ui Plug-in" [Active]
ATL - ATLBundle_20070217.zip :
org.atl.eclipse.adt.builder (1.0.5) "ATL Builder" [Active]
org.atl.eclipse.adt.debug (1.0.9) "ATL Debugger" [Resolved]
org.atl.eclipse.adt.doc.developer (1.0.5) "ATL Developer Documentation"
[Resolved]
org.atl.eclipse.adt.doc.user (1.0.9) "ATL User Documentation" [Resolved]
org.atl.eclipse.adt.editor (1.0.10) "ATL User Interface" [Active]
org.atl.eclipse.adt.perspective (1.0.1) "ATL Perspective" [Resolved]
org.atl.eclipse.adt.wizard (1.0.7) "ATL Wizard" [Active]
org.atl.eclipse.engine (1.0.7) "ATL Engine" [Active]
org.atl.eclipse.km3 (1.0.0) "KM3 injector and extractor plug-in" [Active]
org.atl.engine.repositories.emf4atl (1.0.0) "EMF4ATL Plug-in" [Resolved]
org.atl.engine.repositories.mdr4atl (1.0.0) "MDR4ATL Plug-in" [Resolved]
org.atl.engine.vm (1.0.0) "ATL VM Plug-in" [Active]
Thanx a lot,
Kind regards,
C
FUDForum. Page generated in 0.05097 seconds
