Home » Archived » BIRT » BIRT designer stuck when trying to produce a scripted data source with JNDI context
BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #232634] Fri, 06 April 2007 06:42 Go to next message
Originally posted by: ruby.boyarski.verix.com
hi,
Scripted data sources are great and worked for me when trying to use simple
scenarios (POJOs).
Now I am trying to call an EJB from a scripted data source.
Here's part of the code in the "open" method:
p = new Packages.java.util.Properties();
p.put("java.naming.factory.initial",
"org.jnp.interfaces.NamingContextFactory");
p.put("java.naming.provider.url", "localhost:51099");
initContext = new Packages.javax.naming.InitialContext(p);
In the last line the BIRT studio just gets "stuck" with no response when
clicking the "preview" tab.
When putting these lines in a class file and running it from a "Main" it
works just fine.
When calling the class from the script code the same phenomenon happens -
stuck.
Anyone has an idea how to solve this problem?
Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #232976 is a reply to message #232634] Mon, 09 April 2007 12:58 Go to previous messageGo to next message
Anyone? Help...
"news://news.eclipse.org/eclipse.birt" <ruby.boyarski@verix.com> wrote in
message news:ev586a$k9q$1@build.eclipse.org...
> hi,
> simple scenarios (POJOs).
> works just fine.
> stuck.
> Cheers,
> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #233020 is a reply to message #232634] Mon, 09 April 2007 13:40 Go to previous messageGo to next message
Does the error happen when you preview the report or the dataset?
Jason
news://news.eclipse.org/eclipse.birt wrote:
> hi,
> scenarios (POJOs).
> works just fine.
> stuck.
> Cheers,
> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #233115 is a reply to message #233020] Tue, 10 April 2007 00:16 Go to previous messageGo to next message
It happens when previewing the report.
The screen is just stuck and no output is shown.
Ruby
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:evdtp6$nam$2@build.eclipse.org...
> Jason
>> hi,
>> works just fine.
>> stuck.
>> Cheers,
>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #233255 is a reply to message #233115] Tue, 10 April 2007 11:13 Go to previous messageGo to next message
Can you turn on logging in the Viewer plugin web.xml?
Post the log when the error happens.
Also can you preview the data set?
Jason
> Ruby
>> Jason
>>> hi,
>>> works just fine.
>>> stuck.
>>> Cheers,
>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #233953 is a reply to message #233255] Thu, 12 April 2007 06:32 Go to previous messageGo to next message
Same happens when using an ODA data source (with the same code - invoking an
EJB).
I attached the log.
I have a similiar thread in the "eclipse.dtp" named "ODA driver for EJB
access". Linda Chan answered me there saying that you may be able to provide
help for the same problem (same problem happens in ODA driver and scripted
data source).
For some reason the designer "thinks" that the lookup URL is
" Files/Actuate9/BRDPro/eclipse/plugins/org.eclipse.birt.repor t.viewer_2.1.2.v20061218-0710/birt/WEB-INF/classes/] "
although I haven't specified it anywhere... (the real lookup is my own
string "ejb/GeneralServices")
Thanks for the help,
Ruby
news:evg9h5$8jp$1@build.eclipse.org...
> Jason
>> Thanks,
>> Ruby
>>> Jason
>>>> hi,
>>>> when
>>>> it
>>>> works just fine.
>>>> happens -
>>>> stuck.
>>>> Cheers,
>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234038 is a reply to message #233953] Thu, 12 April 2007 10:24 Go to previous messageGo to next message
Can you try a couple to things.
In your oda specifically log the URL before it gets used.
Run the script version again and attach the log and report.
Jason
> EJB).
> I attached the log.
> data source).
> Ruby
>> Jason
>>> Thanks,
>>> Ruby
>>>> Jason
>>>>> hi,
>>>>> when
>>>>> it
>>>>> works just fine.
>>>>> happens -
>>>>> stuck.
>>>>> Cheers,
>>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234076 is a reply to message #234038] Thu, 12 April 2007 10:43 Go to previous messageGo to next message
Sure.
What is the easiest way to log text? (I tried using System.out but couldn't)
news:evlfeb$tj5$1@build.eclipse.org...
> Thanks
> Jason
>> an EJB).
>> I attached the log.
>> provide help for the same problem (same problem happens in ODA driver and
>> scripted data source).
>> Ruby
>>> Jason
>>>> Thanks,
>>>> Ruby
>>>>> Jason
>>>>>> hi,
>>>>>> when
>>>>>> it
>>>>>> works just fine.
>>>>>> happens -
>>>>>> stuck.
>>>>>> Cheers,
>>>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234097 is a reply to message #234076] Thu, 12 April 2007 11:18 Go to previous messageGo to next message
Here is the text in the "open" method of the scripted data set:
invoker = "";
p.put("java.naming.provider.url", "ami-pc:21099");
objref = initContext.lookup("ejb/GeneralServices"); // Here the
exception happens (the first exception)
data = "11";//invoker.makeCall();
totalRows=1;
currentRow=0;
The exception occurs in the lookup line.
The same code works when in a java Main.
I attached the log file (look at the first exception - connection issue. The
second one is a result of the first).
thanks,
Ruby
message news:evlgi5$5ov$1@build.eclipse.org...
> Sure.
> couldn't)
>> Thanks
>> Jason
>>> invoking
>>> an EJB).
>>> I attached the log.
>>> and
>>> Ruby
>>>> Jason
>>>>> Thanks,
>>>>> Ruby
>>>>>> Jason
>>>>>>> hi,
>>>>>>> when
>>>>>>> "Main"
>>>>>>> it
>>>>>>> works just fine.
>>>>>>> happens -
>>>>>>> stuck.
>>>>>>> Cheers,
>>>>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234203 is a reply to message #234097] Thu, 12 April 2007 12:30 Go to previous messageGo to next message
Ruby,
Can you try installing BRDPro or OS BIRT in a path that has no spaces.
I assume this
should be c:\Program Files?
Run the same example and let us know what happens.
Jason
> invoker = "";
> totalRows=1;
> currentRow=0;
> thanks,
> Ruby
>> Sure.
>> couldn't)
>>> Thanks
>>> Jason
>>>> invoking
>>>> an EJB).
>>>> I attached the log.
>>>> and
>>>> Ruby
>>>>> Jason
>>>>>> Thanks,
>>>>>> Ruby
>>>>>>> Jason
>>>>>>>> hi,
>>>>>>>> when
>>>>>>>> "Main"
>>>>>>>> it
>>>>>>>> works just fine.
>>>>>>>> happens -
>>>>>>>> stuck.
>>>>>>>> Cheers,
>>>>>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234525 is a reply to message #234203] Fri, 13 April 2007 13:42 Go to previous messageGo to next message
I have done what you suggested and it worked like a charm! :-)
Now I have a problem deploying it to the iServer (actually, the problem is
in accessing the data source using the iPortal). I guess I should turn to
Actuate's support for that...
Thanks a lot for your support.
Ruby
news:evlmp5$tiv$1@build.eclipse.org...
> Ruby,
> I assume this
> Jason
>> invoker = "";
>> totalRows=1;
>> currentRow=0;
>> The second one is a result of the first).
>> thanks,
>> Ruby
>>> Sure.
>>> couldn't)
>>>> Thanks
>>>> Jason
>>>>> invoking
>>>>> an EJB).
>>>>> I attached the log.
>>>>> EJB
>>>>> and
>>>>> Ruby
>>>>>> Jason
>>>>>>> Thanks,
>>>>>>> Ruby
>>>>>>>> Jason
>>>>>>>>> hi,
>>>>>>>>> use
>>>>>>>>> response
>>>>>>>>> when
>>>>>>>>> "Main"
>>>>>>>>> it
>>>>>>>>> works just fine.
>>>>>>>>> happens -
>>>>>>>>> stuck.
>>>>>>>>> Cheers,
>>>>>>>>> Ruby
Re: BIRT designer stuck when trying to produce a scripted data source with JNDI context [message #234816 is a reply to message #234525] Mon, 16 April 2007 11:36 Go to previous message
Ruby,
Glad to hear this worked. The iPortal question is probably better
posted on Actuate's support site.
Jason
> Ruby
>> Ruby,
>> I assume this
>> Jason
>>> invoker = "";
>>> totalRows=1;
>>> currentRow=0;
>>> thanks,
>>> Ruby
>>>> Sure.
>>>> couldn't)
>>>>> Thanks
>>>>> Jason
>>>>>> invoking
>>>>>> an EJB).
>>>>>> I attached the log.
>>>>>> EJB
>>>>>> and
>>>>>> Ruby
>>>>>>> Jason
>>>>>>>> Thanks,
>>>>>>>> Ruby
>>>>>>>>> Jason
>>>>>>>>>> hi,
>>>>>>>>>> use
>>>>>>>>>> response
>>>>>>>>>> when
>>>>>>>>>> "Main"
>>>>>>>>>> it
>>>>>>>>>> works just fine.
>>>>>>>>>> happens -
>>>>>>>>>> stuck.
>>>>>>>>>> Cheers,
>>>>>>>>>> Ruby
Previous Topic:Subgrouping by number of rows
Next Topic:HTMLRenderContext setBaseImageURL()
Current Time: Mon Jul 21 21:09:47 EDT 2025
Powered by FUDForum. Page generated in 0.05174 seconds
