Home » Eclipse Projects » GEF » Delete
Delete [message #22675] Tue, 01 October 2002 18:17 Go to next message
Originally posted by: jayuen.alumni.uwaterloo.ca
Hi:
I'm having some problems implementing delete functionality. I am trying to
follow the Logic example as well as going through the GEF source.
Specifically, I wanted to know:
a) Using some print statements in the TargetTool class, I've discovered that
when I click on the LogicDiagramEditPart, the target request is already set
to a DeleteRequest. Why is this and more importantly, WHERE is this set?
b) It seems like there are two ways to delete an object from the Logic
example: pressing the delete key and right clicking and selecting delete.
Where in the Logic code does this occur? Is a Tool of some sort used?? I
know that you must install a a subclass of ComponentEditPolicy in order to
handle the createDeleteCommand method. However, I am having some
difficulties locating where the method is (indirectly) called from the Logic
example.
c) If I want to delete both the glyph and the connections associated with
the glyph, how do I go about doing that? Do I need to subclass a
ContainerEditPolicy? If so, is this functionality handled in the
getDeleteDependantCommand or getOrphanChildren?
any help would be greatly appreciated, thanks!
Jason
Re: Delete [message #22848 is a reply to message #22675] Wed, 02 October 2002 10:04 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
"Jason Yuen" <jayuen@alumni.uwaterloo.ca> wrote in message
news:and5l4$ive$1@rogue.oti.com...
> Hi:
to
that
set
Are you sure this was coming from a println in a Tool? DeleteRequest is
used by the DeleteAction, not any Tools. The DeleteAction appears in a lot
of places. It (The same instance) appears in the context menu, the Global
"delete" Action on the Edit Menu, The Editor's Toolbar, and the
GraphicalViewer's KeyHandler to handle the keystroke for delete.
There are 4, put a breakpoint in DeleteAction.
Logic
> example.
You can do this a thousand ways. One way that we support, but it *ONLY*
works if you can guarantee that your glyph always performs the Delete, is to
have the "node" forward the Delete to its connections. There is a
NodeEditPolicy in GEF specifically to do this forwarding, and the Logic
example demonstrates this. The benefit of forwarding to the Connection is
that it can do additional things that the Node might not need to know about,
like deleting a connection to the connection.
Another way is to put this behavior on the Node itself. You can just
subclass NodeEditPolicy and override the method that generates the delete
command. This means the Node has to know everything about all connections.
However, the benefit is that you can use such an EditPolicy in the Outline
View. In the Outline, you typically can see nodes, but not any connection,
so there is no one to forward the delete to. The Logic Example also
demonstrates this usage in the EditParts that appear on the Tree
(LogicTreeNodeEditPolicy, "Tree" meaning it is used in the TreeViewer).
A third way is to have all EditPolicies delegate to some other "command
factory" helper. One reason for doing this might be that you have places
where Nodes can be deleted, and you aren't even using GEF or EditParts to
display the Nodes.
> Jason
Re: Delete [message #22891 is a reply to message #22848] Wed, 02 October 2002 11:58 Go to previous messageGo to next message
Thanks for the pointers.
with respect to the "command factory" helper that you mentioned, are you
saying that I have a helper class to which the DeleteCommand.execute()
delegates? Right now, my DeleteCommand.execute() simply removes the cihld
that was set to the command in the EditPolicy from the parent that was set
to the comand in the EditPolicy.
Your suggestion was appealing because I eventually want to support the
ability to delete edit parts from other editors that are NOT gui-based
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:anet5k$h6v$1@rogue.oti.com...
> > Hi:
> to
> that
> set
set?
lot
delete.
I
to
> Logic
> > example.
with
to
about,
connections.
connection,
> display the Nodes.
> > Jason
Re: Delete [message #22936 is a reply to message #22891] Wed, 02 October 2002 12:13 Go to previous messageGo to next message
No, I was suggesting that you might have a helper that does:
CommandFactory {
public Command getDeleteNodeCommand(LogicSubpart node){
CompoundCommand command = new CompoundCommand();
//Add all of the other steps necessary to delete a node,
//such as deleting its connections
return command;
And then your NodeEditPolicy.createDeleteCommand(EditPart part) looks like:
return
CommandFactory.getDeleteNodeCommand((LogicSubpart)part.getMo del());
By gui, you mean GEF-based? Commands are still nice to use to support undo,
so you might want to use commands in you non gui-based editor as well.
> > > Hi:
trying
> > to
discovered
> > that
already
> > set
> set?
> lot
Global
> delete.
used??
> I
order
> to
> > Logic
> > > example.
> with
is
> to
is
> about,
delete
> connections.
Outline
> connection,
places
to
> > display the Nodes.
> > > Jason
Re: Delete [message #22979 is a reply to message #22936] Wed, 02 October 2002 12:29 Go to previous messageGo to next message
suppose that my Editor is not GEF-based but uses SWT widgets. Suppose I
have two editors opened on the same resource. If I delete/add something in
the non-GEF based Editor I want it to update my GEF-based Editor (e.g. by
adding a glyph to the GEF-editor) CanI still use GEF commands? Or is the
Request-Command architecture too tightly coupled to GEF?
JY
news:anf4nt$n01$1@rogue.oti.com...
cihld
> CommandFactory {
> return command;
like:
> return
set
undo,
> > > > Hi:
> trying
> > > to
> discovered
> > > that
> already
> > > set
> > set?
is
a
> > lot
> Global
Logic
> > delete.
> used??
> > I
> order
> > to
the
> > > Logic
> > > > example.
> > with
*ONLY*
> is
> > to
Logic
Connection
> is
> > about,
> delete
> > connections.
> Outline
> > connection,
TreeViewer).
"command
> places
> to
> > > display the Nodes.
> > > > Jason
Re: Delete [message #23022 is a reply to message #22979] Wed, 02 October 2002 13:26 Go to previous message
Yes, you can still use commands, but you have lot's of other stuff to do to
make this work. You should probably be sharing the same in-memory model
between the 2 editors. The same is done when you open the same .java file
in Eclipse. The command stacks are usually shared too, but sometimes this
is more difficult.
WSAD does this with several types of editors as well.
news:anf5jt$nk6$1@rogue.oti.com...
in
> JY
you
> cihld
> > CommandFactory {
> > return command;
> like:
> > return
> set
the
> undo,
> > > > > Hi:
> > trying
> > > > to
> > discovered
> > > > that
> > already
> > > > set
this
> > > set?
DeleteRequest
> is
in
> a
> > > lot
> > Global
> Logic
> > > delete.
> > used??
> > > I
> > order
> > > to
> the
> > > > Logic
> > > > > example.
associated
> > > with
> *ONLY*
Delete,
> > is
> > > to
> Logic
> Connection
> > is
know
> > > about,
just
> > delete
> > > connections.
> > Outline
> > > connection,
> TreeViewer).
> "command
> > places
EditParts
> > to
> > > > display the Nodes.
> > > > > Jason
Previous Topic:SWTError: No more handles
Next Topic:Why FreeformGraphicalRootEditPart
Current Time: Fri Jul 11 20:21:40 EDT 2025
Powered by FUDForum. Page generated in 0.09157 seconds
