Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Hello XML World Example error
Re: [buckminster-dev] Hello XML World Example error [message #22670] Mon, 21 July 2008 15:50
Hi Johannes,
Johannes Sebald wrote:
> Hi Thomas,
> thanks for your quick feedback.
> I have tried the example also from here:
> http://www.eclipse.org/buckminster/samples/queries/demo.cque ry
> I got the same error.
> I checked the file that was accused. It contains indeed a date in line 5.
> Maybe it can be a plugin version/installation problem, seems that the SAX
> parser can't parse the file correctly.
The error stems from a DateFormat being unable to parse the date. It
works fine on the platforms where I've tried it. That's why I'm
interested in what Java VM you are using.
Thomas Hallgren
Previous Topic:Re: [buckminster-dev] Hello XML World Example error
Next Topic:Problem with features on a buckminster created updatesite
Current Time: Fri Jul 11 22:03:11 EDT 2025
Powered by FUDForum. Page generated in 0.04463 seconds
