Home » Archived » BIRT » Column Binding problem
Column Binding problem [message #231907] Mon, 02 April 2007 17:15 Go to next message
Originally posted by: pcopeland.avoka.com
I have a report which works fine in the designer / preview mode but is
throwing the following error when I deploy it. The exception is
pr 3, 2007 6:53:25 AM org.eclipse.birt.report.engine.data.dte.DteResultSet
next
SEVERE: Some columns reference in column binding do not exist.
org.eclipse.birt.data.engine.core.DataException: Some columns reference in
org.eclipse.birt.data.engine.executor.ResultClass.doSave(Res ultClass.java:196)
org.eclipse.birt.data.engine.executor.transform.CachedResult Set.doSave(CachedResultSet.java:225)
org.eclipse.birt.data.engine.impl.document.RDSaveUtil.saveFo rGeneration(RDSaveUtil.java:95)
org.eclipse.birt.data.engine.impl.document.RDSaveUtil.saveRe sultIterator(RDSaveUtil.java:60)
org.eclipse.birt.data.engine.impl.document.RDSave.saveResult Iterator(RDSave.java:160).
I saw someone else reported a similiar problem on March 9 - he had to
rebuild his report to get arround the problem. Are there any fixs for this.
I am using Birt - Version: 2.1.2.v20070205-1728
Build id: 200702051728
Philip
Re: Column Binding problem [message #231915 is a reply to message #231907] Mon, 02 April 2007 17:25 Go to previous message
Ok - have tracked this down. I found that there was a column in the table
bindings that did not exist in the query. Once removed it works fine in the
deployment system.
"Philip Copeland" <pcopeland@avoka.com> wrote in message
news:eurrps$ra6$1@build.eclipse.org...
> next
> at
> at
> at
> at
> at
> this.
> Thanks
> Philip
Previous Topic:Set BIRT_VIEWER_DOCUMENT_FOLDER by program
Next Topic:Report Queries executed twice
Current Time: Sun Jul 27 11:02:23 EDT 2025
Powered by FUDForum. Page generated in 0.03263 seconds
