Home » Archived » Voicetools » Cannot create database object
Cannot create database object [message #22669] Wed, 13 May 2009 03:19 Go to next message
In the user's guide, it says: "# Right click on the Databases Folder of
the application in the Projects view.
# Select New Database from the context menu. This will open the New
Database wizard."
But if I right-click the databases folder, there is no "New database"
option under the "New" context menu. All I can see is:
Project
File
Folder
Example
Other
What's the problem?
Thank you in advance
Re: Cannot create database object [message #22761 is a reply to message #22669] Fri, 22 May 2009 11:02 Go to previous message
It sounds like you might be looking in 'File' -> 'New' or in the Java
perspective. Please be sure you are in OpenVXML Perspective ('Window' ->
'Open Perspective' -> 'Other' and select 'OpenVXML Perspective' from the
list). The right-click menu (context menu) for the 'Databases' folder
should show you an option called 'Define Database' (I think the 'New
Database' option was renamed to 'Define Database' at some point). I'll
link to a screenshot, if that's helpful.
<a
href='http://img34.imageshack.us/img34/3608/adddb.jpg'>http://img34.imageshack.us/img34/3608/adddb.jpg</a>
Re: Cannot create database object [message #578569 is a reply to message #22669] Fri, 22 May 2009 11:02 Go to previous message
<a
Previous Topic:Error when exporting application
Next Topic:How to change ANI and DNIS sessions?
Current Time: Sun Jul 13 17:18:25 EDT 2025
Powered by FUDForum. Page generated in 0.25663 seconds
