Home » Archived » Visual Editor (VE) » JOptionPane?
JOptionPane? [message #22654] Thu, 04 March 2004 09:59 Go to next message
Originally posted by: mb.thomas-daily.de
Are there any plans to support JOptionPane?
thanx!
Marcus
Re: JOptionPane? [message #22698 is a reply to message #22654] Thu, 04 March 2004 10:15 Go to previous messageGo to next message
Originally posted by: jdm0532.nospam.cs.rit.edu
You can drop a JOptionPane from the palette on to the free form. Most
of the properties - message, messageType, optionType, wantsInput, can be
configured on it from the property sheet, other than the properties that
take in arrays of Objects (like setOptions, setSelectionValues).
What kind of support for JOptionPane did you have in mind?
- Jeff
> thanx!
> Marcus
Re: JOptionPane? [message #23165 is a reply to message #22654] Fri, 05 March 2004 18:45 Go to previous messageGo to next message
Hi Marcus,
See Jeff's reply - it's on the palette in Swing Components category 3rd
from the bottom.
The only enhancement planned I am aware of is to support dropping of a
single JComponent into the JOptionPane. The message property is typed
to Object, however in the property sheet we have a String editor. It'd
be nice if you could select a JPanel or other swing component from the
palette and drop this right onto the JOptionPane. Arguably we should
then maybe then move it into Swing container category (as it now has the
possibility to act as a component).
If there are more properties you'd like to see surfaced, or any other
features you'd like to see enabled please enter a bugailla feature
request with specific details.
Joe Winchester
Re: JOptionPane? [message #23737 is a reply to message #23165] Tue, 09 March 2004 08:28 Go to previous messageGo to next message
> from the bottom.
Ah, yes. Thank you!
Yes, this is what I need. Is it planned for 1.0 or earlier?
Exactly.
thanx!
Marcus
Re: JOptionPane? [message #24133 is a reply to message #23165] Tue, 09 March 2004 13:44 Go to previous messageGo to next message
So I did :)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=48735
thanx!
Marcus
Re: JOptionPane? [message #24265 is a reply to message #24133] Wed, 10 March 2004 05:10 Go to previous message
> So I did :)
sorry, I meant:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=54177
Marcus
Re: JOptionPane? [message #583406 is a reply to message #22654] Thu, 04 March 2004 10:15 Go to previous message
- Jeff
> thanx!
> Marcus
Re: JOptionPane? [message #583589 is a reply to message #22654] Fri, 05 March 2004 18:45 Go to previous message
Hi Marcus,
from the bottom.
Joe Winchester
Re: JOptionPane? [message #583854 is a reply to message #23165] Tue, 09 March 2004 08:28 Go to previous message
> from the bottom.
Ah, yes. Thank you!
Exactly.
thanx!
Marcus
Re: JOptionPane? [message #583988 is a reply to message #23165] Tue, 09 March 2004 13:44 Go to previous message
So I did :)
thanx!
Marcus
Re: JOptionPane? [message #584052 is a reply to message #24133] Wed, 10 March 2004 05:10 Go to previous message
> So I did :)
sorry, I meant:
Marcus
Previous Topic:iconImage
Next Topic:BoxLayout
Current Time: Tue Jul 22 07:33:18 EDT 2025
Powered by FUDForum. Page generated in 0.05376 seconds
