Home » Archived » BIRT » NoClassDefFoundError exception
NoClassDefFoundError exception [message #231316] Thu, 29 March 2007 16:33 Go to next message
Originally posted by: gokuiuc.yahoo.com
I have been getting a NoClassDefFoundError exception when I ran BIRT inside
Eclipse. I saw the similar newsgroup posts earlier about the issue. This
exception is not occurring consistently. I used ODA to develop my custom
data source and data set, and this exception occurs while previewing the
report or previewing the results in the data set. It is caused when a class
in my ResultSet method calls my classes in other plugins. I know these
classes exist, and they are called fine by BIRT or other plugins, when this
exception doesn't occur. So, is it possible that BIRT is damaging the plugin
dependencies? For your information, I am attaching the exception:
org.eclipse.birt.report.designer.core.runtime.GUIException: Caused by
java.lang.reflect.InvocationTargetException.
org.eclipse.birt.report.designer.core.runtime.GUIException.c reateGUIException(GUIException.java:76)
org.eclipse.birt.report.designer.internal.ui.util.ExceptionH andler.handle(ExceptionHandler.java:123)
org.eclipse.birt.report.designer.internal.ui.util.ExceptionH andler.handle(ExceptionHandler.java:105)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.updateResultsProcess(ResultSetPreviewPage.java:408 )
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.runUpdateResults(ResultSetPreviewPage.java:247)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$1(ResultSetPreviewPage.java:231)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$4.runInUIThread(ResultSetPreviewPage.java:224)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.birt.report.designer.internal.ui.dialogs.BaseDia log.open(BaseDialog.java:95)
org.eclipse.birt.report.designer.internal.ui.views.data.prov iders.DataSetNodeProvider.performEdit(DataSetNodeProvider.ja va:192)
org.eclipse.birt.report.designer.internal.ui.views.DefaultNo deProvider.performRequest(DefaultNodeProvider.java:355)
org.eclipse.birt.report.designer.internal.ui.views.actions.E ditAction.doAction(EditAction.java:80)
org.eclipse.birt.report.designer.internal.ui.views.actions.A bstractElementAction.run(AbstractElementAction.java:64)
org.eclipse.birt.report.designer.internal.ui.views.RenameLis tener.doubleClick(RenameListener.java:211)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:796)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:794)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1227)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1158)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:223)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:220)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:281)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:350)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:479)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.updateResultsProcess(ResultSetPreviewPage.java:404 )
... 49 more
(The actual exception starts here: )
Caused by: java.lang.NoClassDefFoundError
org.topbraid.calendar.model.CalendarUtil.getDatatype(Calenda rUtil.java:52)
at org.topbraid.calendar.model.CalendarUtil.getDate(CalendarUti l.java:76)
at org.topbraid.oda.ResultSet.nodeToDate(ResultSet.java:306)
at org.topbraid.oda.ResultSet.getDate(ResultSet.java:193)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaRe sultSet.getDate(OdaResultSet.java:520)
org.eclipse.birt.data.engine.odaconsumer.ResultSet.getDate(R esultSet.java:285)
org.eclipse.birt.data.engine.odaconsumer.ResultSet.fetch(Res ultSet.java:162)
org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:140)
org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:91)
org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next(ExpandableRowResultSet.java:62)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .populateData(SmartCacheHelper.java:275)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initInstance(SmartCacheHelper.java:250)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initOdaResult(SmartCacheHelper.java:138)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .getResultSetCache(SmartCacheHelper.java:83)
org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.java:51)
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.populateOdiResultSet(PassUtil.java:100)
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.pass(PassUtil.java:66)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.doSinglePass(PassManager.java:123)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.pass(PassManager.java:83)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSet(PassManager.java:65)
org.eclipse.birt.data.engine.executor.transform.ResultSetPop ulator.populateResultSet(ResultSetPopulator.java:210)
org.eclipse.birt.data.engine.executor.transform.CachedResult Set. <init>(CachedResultSet.java:69)
org.eclipse.birt.data.engine.executor.DataSourceQuery.execut e(DataSourceQuery.java:501)
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:330)
org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:743)
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:183)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:148)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.populateRecords(ResultSetPreviewPage.java:430)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$2(ResultSetPreviewPage.java:423)
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$5.run(ResultSetPreviewPage.java:379)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Gokhan
Re: NoClassDefFoundError exception [message #231348 is a reply to message #231316] Thu, 29 March 2007 17:02 Go to previous messageGo to next message
I believe this may be a different error than what was posted earlier
today. Do you have the dependencies set on the other plugins in oda?
Jason
Gokhan wrote:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 49 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Gokhan
Re: NoClassDefFoundError exception [message #231387 is a reply to message #231348] Thu, 29 March 2007 23:43 Go to previous messageGo to next message
Yes, I have the dependencies set correctly on other plugins in oda.
Gokhan
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:euh9gs$82q$1@build.eclipse.org...
>I believe this may be a different error than what was posted earlier today.
> Jason
> Gokhan wrote:
>> Hello,
>> inside Eclipse. I saw the similar newsgroup posts earlier about the
>> issue. This exception is not occurring consistently. I used ODA to
>> develop my custom data source and data set, and this exception occurs
>> while previewing the report or previewing the results in the data set. It
>> is caused when a class in my ResultSet method calls my classes in other
>> plugins. I know these classes exist, and they are called fine by BIRT or
>> other plugins, when this exception doesn't occur. So, is it possible that
>> BIRT is damaging the plugin dependencies? For your information, I am
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> ... 49 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Gokhan
Re: NoClassDefFoundError exception [message #231545 is a reply to message #231387] Fri, 30 March 2007 13:35 Go to previous messageGo to next message
Can you please log a bugzilla entry for this.
I have seen a similar issue when order of plugins being
loaded mattered. So if my ODA ran first it would work,
but if another plugin that used shared plugins ran first then
my plugin would fail. This was due to a class loader issue and
the plugin being in twice I believe. One other thing to try is
to set
setThreadContextClassLoader="false"
To true in the ODA runtime plugin.
Jason
> Gokhan
>> Jason
>> Gokhan wrote:
>>> Hello,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 49 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks,
>>> Gokhan
Re: NoClassDefFoundError exception [message #231656 is a reply to message #231545] Fri, 30 March 2007 20:00 Go to previous message
Thank you very much. I set the "setThreadContextClassLoader = true" and it
works fine now! Since the issue is fixed for now with this setting, I don't
think I would log a bugzilla entry. I might have got a "side-effect" of this
fix though, but I will look more into that.
Thanks!
Gokhan
news:eujhne$ib2$1@build.eclipse.org...
> to set
> Jason
>> Gokhan
>>> Jason
>>> Gokhan wrote:
>>>> Hello,
>>>> It is caused when a class in my ResultSet method calls my classes in
>>>> other plugins. I know these classes exist, and they are called fine by
>>>> BIRT or other plugins, when this exception doesn't occur. So, is it
>>>> possible that BIRT is damaging the plugin dependencies? For your
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 49 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thanks,
>>>> Gokhan
Previous Topic:master page width
Next Topic:NoClassDefFoundError
Current Time: Mon Sep 01 05:14:59 EDT 2025
Powered by FUDForum. Page generated in 0.04187 seconds
