Home » Modeling » OCL » emf+MDT OCL and eclipse versions
emf+MDT OCL and eclipse versions [message #22603] |
Thu, 10 May 2007 00:10  |
Originally posted by: asma.charfi.com
hi
I want to follow the article dealing with "implementing Model Integrity in
EMF with MDT OCL
http://www.eclipse.org/articles/article.php?file=Article-EMF -Codegen-with-OCL/index.html
In this article,the author said that we can use EMF build (milestone M4 of
version 2.3 or later), and MDT OCL component (milestone M5 of version 1.1 or
later)
I used these version in my Eclipse 3.2.2 but the example did not work (I did
not respect the constraints and the model is validated normally)
so I installed Eclipse 3.3 and this time the exemple works correctly (I
recive an error message when I violate one constraints)
the problem that I want to work with Eclipse 3.2.2.
can I find precise version of EMF and OCL working with my Eclipse
R-3.2.2-200702121330
Thanks a lot for your help
asma
Re: emf+MDT OCL and eclipse versions [message #22646 is a reply to message #22603] |
Wed, 09 May 2007 15:38   |
--------------080805090707020201070502
Asma,
Use the latest maintenance versions of EMF and OCL, i.e., EMF 2.2.2 or
later and OCL 1.0.2 or later:
< http://www.eclipse.org/modeling/emf/downloads/?showAll=1& ;hlbuild=R200702131851&project=emf#R200702131851>
< http://www.eclipse.org/modeling/mdt/downloads/?showAll=1& ;hlbuild=R200611161546&project=ocl#R200611161546>
charfi asma wrote:
> hi
> EMF with MDT OCL
> later)
> asma
<html>
<head>
</head>
Asma,<br>
<br>
later and OCL 1.0.2 or later:<a
href=" http://www.eclipse.org/modeling/emf/downloads/?showAll=1& ;amp;hlbuild=R200702131851&project=emf#R200702131851"><br >
</a>
<blockquote><a
href=" http://www.eclipse.org/modeling/mdt/downloads/?showAll=1& ;amp;hlbuild=R200611161546&project=ocl#R200611161546"> http://www.eclipse.org/modeling/emf/downloads/?showAll=1& ;amp;hlbuild=R200702131851&project=emf#R200702131851</a ><br>
<a
href=" http://www.eclipse.org/modeling/mdt/downloads/?showAll=1& ;amp;hlbuild=R200611161546&project=ocl#R200611161546"> http://www.eclipse.org/modeling/mdt/downloads/?showAll=1& ;amp;hlbuild=R200611161546&project=ocl#R200611161546</a ><br>
</blockquote>
<br>
charfi asma wrote:
<blockquote cite="midf1t6jp$4l6$1@build.eclipse.org" type="cite">
<pre wrap="">hi
EMF with MDT OCL
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/articles/article.php?file=Article-EMF -Codegen-with-OCL/index.html"> http://www.eclipse.org/articles/article.php?file=Article-EMF -Codegen-with-OCL/index.html</a>
later)
asma
</pre>
</blockquote>
<br>
</body>
</html>
--------------080805090707020201070502--
Re: emf+MDT OCL and eclipse versions [message #22688 is a reply to message #22646] |
Thu, 10 May 2007 03:13   |
------=_NextPart_000_001A_01C79298.15464700
charset="iso-8859-1"
thank you for your help Ed,
I installed EMF 2.2.2 et OCL 1.0.2 and I followed the example but
when I generate all (from the employee.genmodel) JETEmitter was not =
generated in /org.eclipse.ocl.examples.codegen/templates (although I =
create a folder templates and activate dynamic templates)
and when I run the application I did not find Employee model in =
"Exemple EMF Model Creation wizard" =20
P S : when i installed ocl 1.0.2 it appers in my manage configuration =
with this name "EMFT OCL SDK 1.0......",
so what's the differences beteween EMF with OCL MDT and EMFT OCL SDK?
I know that I ask many questions, but I have to inderstand how does the =
constraints' validation works
thank you again
"Ed Merks" <merks@ca.ibm.com> a =E9crit dans le message de news: =
f1t7v9$c94$1@build.eclipse.org...
Asma,
Use the latest maintenance versions of EMF and OCL, i.e., EMF 2.2.2 or =
http://www.eclipse.org/modeling/emf/downloads/?showAll=3D1&a mp;hlbuild=3DR200=
702131851&project=3Demf#R200702131851
http://www.eclipse.org/modeling/mdt/downloads/?showAll=3D1&a mp;hlbuild=3DR200=
611161546&project=3Docl#R200611161546
charfi asma wrote:=20
hi
I want to follow the article dealing with "implementing Model Integrity =
in=20
EMF with MDT OCL
http://www.eclipse.org/articles/article.php?file=3DArticle-E MF-Codegen-wi=
th-OCL/index.html
In this article,the author said that we can use EMF build (milestone M4 =
of=20
version 2.3 or later), and MDT OCL component (milestone M5 of version =
1.1 or=20
later)
I used these version in my Eclipse 3.2.2 but the example did not work (I =
did=20
so I installed Eclipse 3.3 and this time the exemple works correctly (I=20
can I find precise version of EMF and OCL working with my Eclipse=20
asma=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16414" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV>
<DIV><FONT face=3DArial size=3D2>thank you for your help =
Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I installed EMF 2.2.2 et OCL 1.0.2 and =
I followed=20
the example but</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>when I generate all (from the =
employee.genmodel)=20
JETEmitter was not generated in =
/org.eclipse.ocl.examples.codegen/templates=20
(although I create a folder templates and activate dynamic=20
templates)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and when I run the application I did =
not find=20
Employee model in "Exemple EMF Model Creation wizard"=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>P S : when i installed ocl 1.0.2 it =
appers in my=20
manage configuration with this name "EMFT OCL SDK =
1.0......",</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>so what's the differences beteween EMF =
with=20
OCL MDT and EMFT OCL SDK?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I know that I ask many questions, but I =
have to=20
inderstand how does the constraints' validation works</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thank you again</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
a =E9crit dans le message de news: <A=20
href=3D"mailto:f1t7v9$c94$1@build.eclipse.org">f1t7v9$c94$1@build.eclipse=
..org</A>...</DIV>Asma,<BR><BR>Use=20
later and=20
OCL 1.0.2 or later:<A=20
href=3D" http://www.eclipse.org/modeling/emf/downloads/?showAll=3D1&a mp;amp;hl=
build=3DR200702131851&project=3Demf#R200702131851"><BR ></A>
<BLOCKQUOTE><A=20
href=3D" http://www.eclipse.org/modeling/mdt/downloads/?showAll=3D1&a mp;amp;hl=
build=3DR200611161546&project=3Docl#R200611161546">http://www.eclipse=
..org/modeling/emf/downloads/?showAll=3D1&hlbuild=3D R200702131851&=
project=3Demf#R200702131851</A><BR><A=20
..org/modeling/mdt/downloads/?showAll=3D1&hlbuild=3D R200611161546&=
project=3Docl#R200611161546</A><BR></BLOCKQUOTE><BR>charfi=20
asma wrote:=20
<BLOCKQUOTE cite=3Dmidf1t6jp$4l6$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">hi
in=20
EMF with MDT OCL
<A class=3Dmoz-txt-link-freetext =
href=3D" http://www.eclipse.org/articles/article.php?file=3DArticle-E MF-Co=
degen-with-OCL/index.html">http://www.eclipse.org/articles/article.php?fi=
le=3DArticle-EMF-Codegen-with-OCL/index.html</A>
of=20
1.1 or=20
later)
did=20
asma=20
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_001A_01C79298.15464700--
Re: emf+MDT OCL and eclipse versions [message #22820 is a reply to message #22732] |
Thu, 10 May 2007 08:50   |
Hi, Asma,
The OCL 1.1 release has many significant changes over 1.0, including the
user of EMF's support for modeling generics. You won't be able to use the
example in the article with the 1.0.x release of OCL.
The same ideas will work with OCL 1.0, just the code and templates will look
different. So, if you use the article as a guide, you should be able to
make it work. It'll just be more work than copy-and-paste.
Alternatively, you could update to Eclipse 3.3, EMF 2.3, and OCL 1.1 to take
advantage of numerous new features and other improvements in both of these
APIs. :-)
Christian
Ed Merks wrote:
> Asma,
> It seems to me that Christian made some changes to update the examples
> to work with EMF 2.3. So I'll have to rely on him to help answer this
> question.
>> thank you again
>> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> a écrit
>> dans le message de news: f1t7v9$c94$1@build.eclipse..org
>> <mailto:f1t7v9$c94$1@build.eclipse.org>...
>> Asma,
>> 2.2.2 or later and OCL 1.0.2 or later:
http://www.eclipse..org/modeling/emf/downloads/?showAll=1&am p;hlbuild=R200702131851&project=emf#R200702131851
http://www.eclipse..org/modeling/mdt/downloads/?showAll=1&am p;hlbuild=R200611161546&project=ocl#R200611161546
>> charfi asma wrote:
>>> hi
>>> Integrity in EMF with MDT OCL
>>> (milestone M4 of version 2.3 or later), and MDT OCL component
>>> (milestone M5 of version 1.1 or later)
>>> work (I did not respect the constraints and the model is validated
>>> normally) so I installed Eclipse 3.3 and this time the exemple works
>>> correctly (I recive an error message when I violate one constraints)
>>> asma
Re: emf+MDT OCL and eclipse versions [message #23034 is a reply to message #22820] |
Fri, 11 May 2007 13:37  |
hi christian
first, I want to thank you for your help
I have slides to present to my work's team and I want to present for them
the exemple using Eclipse 3.2 because all the team's members worrks with
this version
it's not really a problem, I will try to make it work ;-)
I want to verify if using EMF with CDT OCL (using in the example) is
equivalent to using EMFT (OCL+Validation)?
I have to explain the differences between them to my team's members
thank you again
"Christian W. Damus" <cdamus@ca.ibm.com> a
Re: emf+MDT OCL and eclipse versions [message #23075 is a reply to message #23034] |
Fri, 11 May 2007 09:29  |
Hi, Asma,
Here is my reply from the EMF newsgroup:
Ah, OK. The article deals strictly with the EMF and MDT OCL components. It
does not involve the EMF Validation component (formerly EMFT Validation).
So, in your Eclipse 3.2 environment, you'd be working strictly with EMF
2.2.x and EMFT OCL 1.0.x (also available from the MDT project as MDT OCL
1.0.x).
EMF Validation includes an org.eclipse.emf.validation.ocl features that
provides support for defining constraints within its framework, using OCL.
The article doesn't go near that.
This week's M7 build of the MDT OCL and EMF Validation SDKs will have
much-improved Programmer's Guide documentation that should help to
elucidate the relationship. If you're in a hurry, it is all checked in
already in CVS in these locations:
/cvsroot/modeling/
org.eclipse.emf/
org.eclipse.emf.validation/
doc/
org.eclipse.emf.validation.doc/
references/overview/*.html
org.eclipse.mdt/
org.eclipse.ocl/
doc/
org.eclipse.ocl.doc/
HTH,
Christian
charfi asma wrote:
> hi christian
> this version
> thank you again
> "Christian W. Damus" <cdamus@ca.ibm.com> a �rit dans le message de news:
> f1v4dl$udj$1@build.eclipse.org...
<snip>
Current Time: Tue Jul 15 00:03:00 EDT 2025
Powered by FUDForum. Page generated in 0.04846 seconds
