Home » Archived » DSDP - Real-Time Software Components (RTSC) » How to include opts-file?
How to include opts-file? [message #1917] Tue, 17 March 2009 14:54 Go to next message
Champs,
I'm trying to include an opts-file from another opts-file, but I'm getting the following error.
xs.opts
--xdcpath=^/../imports;/db/toolsrc/library/tools/packages;/h ome/xlibrary/trees/avalaprod/avalaprod-d23/product/bios_6_20 _00_23/packages;/home/xlibrary/trees/ipc/ipc-b27/product/ipc _1_00_00_27/packages;^/ti/sdo/fc/utils/bridgeconfig;/db/tool src/library/tools/vendors/ti/edma3_lld/edma3_lld_1_06_00_01/ packages
xdc.opts
@xs.opts
XDCARGS=profile=debug
xdc @$fc/xdc.opts .interfaces -PR .
/db/toolsrc/library/tools/vendors/xdc/xdctools_3_15_00_28/Li nux/xdc: unable to e
xpand command line arguments: can't open argument file
Any suggestions. Thanks.
~ Ramsey
Re: How to include opts-file? [message #1931 is a reply to message #1917] Wed, 18 March 2009 10:55 Go to previous messageGo to next message
Ramsey Harris wrote:
> Champs,
> xs.opts
> xdc.opts
> @xs.opts
> unable to e
> ~ Ramsey
The error indicates that xs.opts file can not be opened. Is it in the
current working directory when you run xdc? It appears that xdc.opts is
not.
Re: How to include opts-file? [message #1945 is a reply to message #1931] Fri, 27 March 2009 19:50 Go to previous messageGo to next message
>> Champs,
>> xs.opts
>> xdc.opts
>> @xs.opts
>> unable to e
>> ~ Ramsey
> not.
Using a full pathname to xs.opts in xdc.opts worked. I was not in the same directory as the opts files when I ran the xdc command. But it would be more useful if I could specify xs.opts relative to xdc.opts.
Re: How to include opts-file? [message #1956 is a reply to message #1945] Tue, 31 March 2009 11:01 Go to previous message
>>> xdc.opts
>>> @xs.opts
>>> unable to e
>>> ~ Ramsey
>> is not.
Agreed. It would also be useful to be able to use environment variables
from within these files.
A useful enhancement request might be to add the ability to reference
environment variables using a syntax similar to make (e.g., $(HOME)).
At the same time we can create a few "builtins" that allow on to
reference the script's location, basename, etc. This would allow you to
easily compose a file that references other opts files in the same or
releated directories.
Previous Topic:RTSC Tutorial at EclipseCon 2009
Next Topic:Proper way to configure C only target
Current Time: Tue Jul 22 12:54:52 EDT 2025
Powered by FUDForum. Page generated in 0.03895 seconds
