Home » Language IDEs » Java Development Tools (JDT) » Starting program from eclipse
Starting program from eclipse [message #22568] Wed, 14 May 2003 08:58 Go to next message
Originally posted by: greifeneder.racon-linz.at
Hello
I have a simple problem, but I haven't found a solution after many tries.
Therefore I'm asking here.
I hope anyone can reproduce this Exception
java.security.NoSuchAlgorithmException: Algorithm DES not available
at javax.crypto.SunJCE_b.a(DashoA6275)
at javax.crypto.SecretKeyFactory.getInstance(DashoA6275)
at Test.main(Test.java:126)
Exception in thread "main"
I'm using Eclipse 2.1.0 Build id: 200303272130
My JDK is 1.4.1_01
public static void main(String[] args) throws Exception {
SecretKeyFactory skf = SecretKeyFactory.getInstance("DES");
Re: Starting program from eclipse [message #22615 is a reply to message #22568] Wed, 14 May 2003 09:27 Go to previous message
I forgot:
If I run the program from commandline, it works without a problem. Only
starting from eclipse in run or debug mode throws the exception
Mike
Previous Topic:font for outline view
Next Topic:Pls make my eclipse to look for images
Current Time: Tue Jul 22 01:45:10 EDT 2025
Powered by FUDForum. Page generated in 0.04498 seconds
