Home » Archived » Maven Integration (M2E) » Add maven dependency?
Add maven dependency? [message #22501] Wed, 04 March 2009 03:56 Go to next message
Originally posted by: sadsdfd.asds.com
I have made a maven parent project and two child maven modules. I would like
to add a dependency to the maven parent that the children should enherit.
I right click the maven parent project and choose Properties -> Java Build
Path -> Libraries.
I then press the the Add External JARs... and choose the .jar file. But the
dependency is not located under the Maven Dependencies but instead it gets
added as "Referenced Libraries".
How do I add a new Maven Dependency without doing it manually in the pom.xml
file?
Re: Add maven dependency? [message #22545 is a reply to message #22501] Wed, 04 March 2009 07:20 Go to previous messageGo to next message
You should use popup menu "Maven / Add Dependency" on your project or
pom.xml. Also, pom editor provides a structured form-based UI for
editing of all sections of the pom.xml
regards,
Eugene
> would like to add a dependency to the maven parent that the children
> should enherit.
> Build Path -> Libraries.
> But the dependency is not located under the Maven Dependencies but
> instead it gets added as "Referenced Libraries".
> pom.xml file?
Re: Add maven dependency? [message #23224 is a reply to message #22545] Mon, 23 March 2009 09:55 Go to previous messageGo to next message
I have tried that but it still gets located under "Referenced Libraries" and
not under the "Maven Dependencies" section.
"Eugene Kuleshov" <eu@md.pp.ru> wrote in message
news:golrlt$9ef$1@build.eclipse.org...
> pom.xml. Also, pom editor provides a structured form-based UI for editing
> regards,
> Eugene
>> like to add a dependency to the maven parent that the children should
>> enherit.
>> the dependency is not located under the Maven Dependencies but instead it
>> pom.xml file?
Re: Add maven dependency? [message #23345 is a reply to message #23224] Mon, 23 March 2009 11:09 Go to previous message
Originally posted by: igor.ifedorenko.com
Just to clarify, you need to add required dependencies to
<dependencies/> section of pom.xml file of the parent project. The
easiest way to do this is by using m2e GUI as Eugene has suggested, but
you should see/make changes in plain text (or xml) editor as well. Also
note that Maven dependencies are identified using
groupId/artifactId/version "coordinates", so you should see something
like this in pom.xml file.
<dependency>
<groupId>org.apache.maven.mercury</groupId>
<artifactId>mercury-plexus</artifactId>
<version>1.0-alpha-6-SNAPSHOT</version>
</dependency>
You should not modify project java build path directly.
Igor
> and not under the "Maven Dependencies" section.
>> regards,
>> Eugene
>>> should enherit.
>>> pom.xml file?
Previous Topic:Import multi-module project from Bazaar SCM
Next Topic:BIRT dependencies form maven?
Current Time: Sun Aug 31 17:48:33 EDT 2025
Powered by FUDForum. Page generated in 0.03838 seconds
