Home » Archived » Visual Editor (VE) » - Problem creating new Visual Class with 3.0M7.
- Problem creating new Visual Class with 3.0M7. [message #22424] Thu, 04 March 2004 08:10 Go to next message
Originally posted by: rolf.eisenhut.technodata.de
Is there somebody who can help me with this issue.
When i'm creating a new visual class i get the following message
Creation of element failed
org/eclipse/core/tuntime/Plugin
The class will not ber created.
I've appended the confiuration Info and the Errorlog.
regards Rolf
*** Date: 04.03.04 13:57
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.debug.startupTime=1078404988077
eclipse.noLazyRegistryCacheLoading=true
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\j2re1.4.2_03\lib\endorsed
java.ext.dirs=C:\j2re1.4.2_03\lib\ext
java.home=C:\j2re1.4.2_03
java.io.tmpdir=C:\DOKUME~1\Eisenhut\LOKALE~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\System32; C:\WINDOWS;C:\or
acle\ora81\bin;C:\Oracle\ora92\bin;C:\oracle\ora92Client\bin ;C:\PROGRA~1\MIC
ROS~4\Common\msdev98\BIN;C:\PROGRA~1\MICROS~4\VC98\BIN;C:\PR OGRA~1\MICROS~4\
Common\TOOLS\WINNT;C:\PROGRA~1\MICROS~4\Common\TOOLS;C:\WIND OWS\system32;C:\
WINDOWS;C:\WINDOWS\System32\Wbem;c:\forte\install\bin;c:\for te\objectivity\b
in;C:\Programme\Resource Kit\;C:\Programme\WinRAR;
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_03-b02
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_03
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_03-b02
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.eclipse.osgi.framework.defaultadaptor.bundledir=c:/eclip se/.config/bundl
es
org.osgi.framework.executionenvironment=
org.osgi.framework.language=de
org.osgi.framework.os.name=Windows XP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.osgi.services, org.eclipse.osgi.util,
org.eclipse.core.runtime@2, org.eclipse.update.configurator@3
osgi.configuration.area=file:c:/eclipse/.config
osgi.framework=file:c:/eclipse/plugins/org.eclipse.osgi_3.0. 0/
osgi.framework.beginningstartlevel=1
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar,
defaultAdaptor.jar, eclipseAdaptor.jar
osgi.installLocation=file:c:/eclipse/
osgi.instance.area=file:C:/eclipse/workspace
osgi.manifest.cache=c:/eclipse/.config/manifests
osgi.nl=de_DE
osgi.os=win32
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\j2re1.4.2_03\lib\rt.jar;C:\j2re1.4.2_ 03\lib\i18n.jar;
C:\j2re1.4.2_03\lib\sunrsasign.jar;C:\j2re1.4.2_03\lib\jsse. jar;C:\j2re1.4.2
_03\lib\jce.jar;C:\j2re1.4.2_03\lib\charsets.jar;C:\j2re1.4. 2_03\classes
sun.boot.library.path=C:\j2re1.4.2_03\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=
user.country=DE
user.dir=C:\eclipse
user.home=C:\Dokumente und Einstellungen\Eisenhut
user.language=de
user.name=Eisenhut
user.timezone=Europe/Berlin
user.variant=
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
com.ibm.wtp.emf.integration (1.0.0) "com.ibm.wtp.emf.integration"
org.eclipse.emf (2.0.0) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.0.0) "EMF Programmers Guide"
org.eclipse.gef (3.0.0) "Graphical Editing Framework"
org.eclipse.jdt (3.0.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.0) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.0.0) "Java EMF Model"
org.eclipse.jem.source (1.0.0) "Java EMF Model Source"
org.eclipse.pde (3.0.0) "Eclipse Plug-in Development Environment"
org.eclipse.platform (3.0.0) "Eclipse Platform"
org.eclipse.platform.source (3.0.0) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.0) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.0.0) "Eclipse SDK Examples"
org.eclipse.team.extras (3.0.0) "Eclipse FTP and WebDAV Support"
org.eclipse.uml2 (1.0.0) "UML2"
org.eclipse.uml2.examples (1.0.0) "UML2 Examples"
org.eclipse.ve (1.0.0) "Visual Editor"
org.eclipse.ve.examples (1.0.0) "Visual Editor Examples"
org.eclipse.ve.sdk (1.0.0) "Visual Editor SDK"
org.eclipse.ve.source (1.0.0) "Visual Editor Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model"
com.ibm.wtp.common (1.0.0) "com.ibm.wtp.common"
com.ibm.wtp.emf (0.5.0) "EMF Utilities"
com.ibm.wtp.emf.workbench (0.5.0) "EMF Workbench"
org.apache.ant (1.6.1) "Apache Ant"
org.apache.lucene (1.3.0) "Apache Lucene"
org.apache.xerces (4.0.13) "Xerces Based XML Parser"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.0) "Ant UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.compare.examples (3.0.0) "Compare Example"
org.eclipse.compare.examples.xml (3.0.0) "XML Compare Support"
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.0) "File Buffers"
org.eclipse.core.resources (3.0.0) "Core Resource Management"
org.eclipse.core.runtime (3.0.0) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.0) "Debug Core"
org.eclipse.debug.ui (3.0.0) "Debug UI"
org.eclipse.draw2d (3.0.0) "Draw2d"
org.eclipse.emf.codegen (2.0.0) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.0.0) "EMF Ecore Code Generation"
org.eclipse.emf.codegen.ecore.ui (2.0.0) "EMF Ecore Code Generation UI"
org.eclipse.emf.codegen.ui (2.0.0) "EMF Template Code Generator UI"
org.eclipse.emf.common (2.0.0) "EMF Common"
org.eclipse.emf.common.ui (2.0.0) "EMF Common UI"
org.eclipse.emf.ecore (2.0.0) "EMF Ecore"
org.eclipse.emf.ecore.change (2.0.0) "EMF Ecore Change Model"
org.eclipse.emf.ecore.change.edit (2.0.0) "EMF Ecore Change Edit Support"
org.eclipse.emf.ecore.edit (2.0.0) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.0.0) "Sample Ecore Editor"
org.eclipse.emf.ecore.xmi (2.0.0) "EMF XMI"
org.eclipse.emf.edit (2.0.0) "EMF Edit"
org.eclipse.emf.edit.ui (2.0.0) "EMF Edit UI"
org.eclipse.emf.mapping (2.0.0) "EMF Mapping "
org.eclipse.emf.mapping.ui (2.0.0) "EMF Mapping UI"
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.0) "Help System Base"
org.eclipse.help.examples.ex1 (3.0.0) "Online Help Sample"
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.0) "Help System UI"
org.eclipse.help.webapp (3.0.0) "Help System Webapp"
org.eclipse.jdt.core (3.0.0) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.0) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.0) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.0) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.0) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.0) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.0) "Java Development Tools JUnit runtime
support"
org.eclipse.jdt.launching (3.0.0) "Java Development Tools Launching Support"
org.eclipse.jdt.ui (3.0.0) "Java Development Tools UI"
org.eclipse.jdt.ui.examples.javafamily (3.0.0) "Java Development Tools
JavaFamily Example"
org.eclipse.jdt.ui.examples.projects (3.0.0) "Java Development Tools Example
Projects"
org.eclipse.jem.beaninfo (1.0.0) "Java EMF Model BeanInfo (Introspection)
Support"
org.eclipse.jem.beaninfo.ui (1.0.0) "Java EMF Model BeanInfo (Introspection)
UI"
org.eclipse.jem.proxy (1.0.0) "Java EMF Model Proxy Support"
org.eclipse.jem.workbench (1.0.0) "Java EMF Model Workbench Support"
org.eclipse.jface (3.0.0) "JFace"
org.eclipse.jface.text (3.0.0) "JFace Text"
org.eclipse.osgi (3.0.0) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "Eclipse OSGi Services"
org.eclipse.osgi.util (3.0.0) "Eclipse OSGi Utilities"
org.eclipse.pde.build (3.0.0) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (3.0.0) "Plug-in Development Core"
org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
org.eclipse.pde.runtime (3.0.0) "Plug-in Development Environment Runtime"
org.eclipse.pde.source (3.0.0) "Eclipse Plug-in Development Environment
Source Code"
org.eclipse.pde.ui (3.0.0) "Plug-in Development UI"
org.eclipse.platform.doc.isv (3.0.0) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.0) "Eclipse Workbench User Guide"
Resources"
org.eclipse.sdk.examples.source (3.0.0) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.search (3.0.0) "Search Support"
org.eclipse.swt (3.0.0) "Standard Widget Toolkit"
org.eclipse.swt.examples (3.0.0) "SWT Standalone Examples Plugin"
org.eclipse.swt.examples.browser (3.0.0) "SWT Browser Example Plugin"
org.eclipse.swt.examples.controls (3.0.0) "SWT Controls Example Plugin"
org.eclipse.swt.examples.launcher (3.0.0) "SWT Launcher Example Plugin"
org.eclipse.swt.examples.layouts (3.0.0) "SWT Layout Example Plugin"
org.eclipse.swt.examples.ole.win32 (3.0.0) "SWT OLE Example Plugin (Win32)"
org.eclipse.swt.examples.paint (3.0.0) "SWT Paint Example Plugin"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.0) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.0) "CVS Team Provider UI"
org.eclipse.team.examples.filesystem (3.0.0) "Eclipse Team File System
Example"
org.eclipse.team.extras.source (3.0.0) "%pluginName"
org.eclipse.team.ftp (3.0.0) "FTP Team Provider"
org.eclipse.team.ui (3.0.0) "Team Support UI"
org.eclipse.team.webdav (3.0.0) "WebDAV Team Provider"
org.eclipse.text (3.0.0) "Text"
org.eclipse.tomcat (4.1.29) "Tomcat Wrapper"
org.eclipse.ui (3.0.0) "Eclipse UI"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.0) "Default Text Editor"
org.eclipse.ui.examples.javaeditor (3.0.0) "JFace Text Example"
org.eclipse.ui.examples.multipageeditor (2.1.0) "Multi-Page Editor Example"
org.eclipse.ui.examples.propertysheet (2.1.0) "User File Editor"
org.eclipse.ui.examples.readmetool (2.1.0) "Readme File Editing Tool"
org.eclipse.ui.externaltools (3.0.0) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.0) "Eclipse IDE UI"
org.eclipse.ui.versioncheck (3.0.0) "Eclipse Version Check"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.workbench (3.0.0) "Workbench"
org.eclipse.ui.workbench.texteditor (3.0.0) "Text Editor Framework"
org.eclipse.uml2.edit (1.0.0) "UML2 Edit Support"
org.eclipse.uml2.editor (1.0.0) "UML2 Editor"
org.eclipse.uml2.examples.ui (1.0.0) "UML2 Examples UI"
org.eclipse.uml2.resources (1.0.0) "UML2 Resources"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.0) "Install/Update Core"
org.eclipse.update.scheduler (3.0.0) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.0) "Install/Update UI"
org.eclipse.update.ui.forms (3.0.0) "Install/Update Forms"
org.eclipse.ve.cde (1.0.0) "Visual Editor Common Data Editor"
org.eclipse.ve.doc (1.0.0) "Visual Editor User Guide"
org.eclipse.ve.examples.source (1.0.0) "Visual Editor Examples Source"
org.eclipse.ve.java.core (1.0.0) "Visual Editor Java Core"
org.eclipse.ve.jfc (1.0.0) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.propertysheet (1.0.0) "Visual Editor PropertySheet"
org.eclipse.ve.swt (1.0.0) "Visual Editor for Standard Widget Toolkit"
org.eclipse.webdav (3.0.0) "WebDAV Client"
org.junit (3.8.1) "JUnit Testing Framework"
*** User Preferences:
#Thu Mar 04 13:57:48 CET 2004
org.eclipse.jdt.core=3.0.0
org.eclipse.jdt.launching/org.eclipse.jdt.launching.PREF_VM_ XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
>\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" name\="j2re1.4.2_03" path\="C\:\\j2re1.4.2_03"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n</vmType>\r\n</v
mSettings>\r\n
org.eclipse.jdt.ui/fontPropagated=true
org.eclipse.jdt.core/org.eclipse.jdt.core.builder.resourceCo pyExclusionFilte
r=*.launch
org.eclipse.ui.ide/WELCOME_DIALOG=false
org.eclipse.jdt.ui/tabWidthPropagated=true
org.eclipse.jdt.core/org.eclipse.jdt.core.codeComplete.visib ilityCheck=enabl
ed
org.eclipse.jdt.core/org.eclipse.jdt.core.classpathContainer .VETest|org.ecli
pse.jdt.launching.JRE_CONTAINER=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<classpath>\r\n<classpathentry kind\="lib"
path\="C\:/j2re1.4.2_03/lib/rt.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/j2re1.4.2_03/lib/sunrsasign.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/j2re1.4.2_03/lib/jsse.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/j2re1.4.2_03/lib/jce.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/j2re1.4.2_03/lib/charsets.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/j2re1.4.2_03/lib/ext/dnsns.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/j2re1.4.2_03/lib/ext/ldapsec.jar"/>\r\n<classpathentry
kind\="lib"
path\="C\:/j2re1.4.2_03/lib/ext/localedata.jar"/>\r\n<classpathentry
kind\="lib"
path\="C\:/j2re1.4.2_03/lib/ext/sunjce_provider.jar"/>\r\n </classpath>\r\n
org.eclipse.ui.ide/INTRO=false
org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Courier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier
New;1|Courier|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Couri er;1|Lucida
Console|9|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Lucida Console;
org.eclipse.jdt.launching=3.0.0
org.eclipse.jdt.ui=3.0.0
org.eclipse.ui.ide=3.0.0
*** Update Manager Log:
Configuration=04.03.2004 13:56:28
Is current configuration=false
*** Error Log:
!SESSION Mrz 04, 2004
13:57:28.998 ---------------------------------------------
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
!ENTRY org.eclipse.core.runtime 4 2 Mrz 04, 2004 13:57:29.14
!MESSAGE Problems encountered starting up plug-in:
"org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.star t() ".
!STACK 0
org.eclipse.osgi.framework.internal.core.BundleContext.start Activator(Bundle
Context.java:1010)
org.eclipse.osgi.framework.internal.core.BundleContext.start (BundleContext.j
ava:972)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.j
ava:403)
at org.eclipse.osgi.framework.internal.core.Bundle.start(Bundle .java:332)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(Plugin
Descriptor.java:432)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescripto
r.java:410)
at org.eclipse.core.runtime.Platform.getPlugin(Platform.java:39 0)
org.eclipse.ve.internal.java.vce.templates.TemplateUtil.getP luginAndPreReqJa
rPath(TemplateUtil.java:138)
rPath(TemplateUtil.java:120)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.ge
tGeneratorInstance(NewVisualClassCreationWizard.java:97)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.ap
plyContributor(NewVisualClassCreationWizard.java:293)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.fi
nishPage(NewVisualClassCreationWizard.java:341)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.
java:100)
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation
..java:34)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java
:700)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1567)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1586)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3164)
org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRu
nnableAdapter.java:52)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.jav
a:302)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:252)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 758)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElemen
tWizard.java:107)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:608)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:321)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:402)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2352)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2033)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:643 )
at org.eclipse.jface.window.Window.open(Window.java:623)
org.eclipse.ui.internal.ide.NewWizardShortcutAction.run(NewW izardShortcutAct
ion.java:98)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:550)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:502)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContribu
tionItem.java:435)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1566)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1542)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:263)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:256)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:100)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Nested exception:
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/Plugin
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.define
Class(DefaultClassLoader.java:298)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClass
Loader.java:99)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findCl
assImpl(DefaultClassLoader.java:287)
ass(DefaultClassLoader.java:176)
org.eclipse.osgi.framework.adaptor.BundleClassLoader.findLoc alClass(BundleCl
assLoader.java:261)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
assLoader.java:73)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
oader.java:321)
org.eclipse.osgi.framework.internal.core.BundleLoader.requir eClass(BundleLoa
der.java:286)
org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredClass(Bund
leLoader.java:918)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:349)
org.eclipse.osgi.framework.adaptor.BundleClassLoader.loadCla ss(BundleClassLo
ader.java:115)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
Loader.java:99)
assLoader.java:261)
assLoader.java:73)
oader.java:321)
..java:352)
ader.java:115)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader
..java:259)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.jav
a:331)
org.eclipse.osgi.framework.internal.core.Bundle.loadClass(Bu ndle.java:1344)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivatio
n(PluginDescriptor.java:475)
Descriptor.java:442)
r.java:410)
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivato
r.java:48)
org.eclipse.osgi.framework.internal.core.BundleContext$1.run (BundleContext.j
ava:993)
Context.java:989)
ava:972)
ava:403)
r.java:410)
java:100)
..java:34)
:700)
a:302)
tWizard.java:107)
ion.java:98)
tem.java:502)
tionItem.java:435)
java:256)
!ENTRY org.eclipse.core.runtime 4 2 Mrz 04, 2004 13:57:29.108
!MESSAGE Attempt to activate a disabled plug-in: "org.eclipse.emf.common".
!STACK 0
Context.java:1010)
ava:972)
ava:403)
r.java:410)
rPath(TemplateUtil.java:152)
java:100)
..java:34)
:700)
a:302)
tWizard.java:107)
ion.java:98)
tem.java:502)
tionItem.java:435)
java:256)
Nested exception:
org.eclipse.core.runtime.CoreException: Attempt to activate a disabled
org.eclipse.core.internal.plugins.PluginDescriptor.throwExce ption(PluginDesc
riptor.java:383)
org.eclipse.core.internal.plugins.PluginDescriptor.pluginAct ivationEnter(Plu
ginDescriptor.java:361)
Descriptor.java:440)
r.java:410)
r.java:48)
ava:993)
Context.java:989)
ava:972)
ava:403)
r.java:410)
java:100)
..java:34)
:700)
a:302)
tWizard.java:107)
ion.java:98)
tem.java:502)
tionItem.java:435)
java:256)
!ENTRY org.eclipse.core.runtime 4 2 Mrz 04, 2004 13:57:29.170
!STACK 0
Context.java:1010)
ava:972)
ava:403)
r.java:410)
java:100)
..java:34)
:700)
a:302)
tWizard.java:107)
ion.java:98)
tem.java:502)
tionItem.java:435)
java:256)
Nested exception:
riptor.java:383)
r.java:410)
r.java:48)
ava:993)
Context.java:989)
ava:972)
ava:403)
r.java:410)
java:100)
..java:34)
:700)
a:302)
tWizard.java:107)
ion.java:98)
tem.java:502)
tionItem.java:435)
java:256)
!ENTRY org.eclipse.core.runtime 4 2 Mrz 04, 2004 13:57:29.186
!STACK 0
Context.java:1010)
ava:972)
ava:403)
r.java:410)
java:100)
..java:34)
:700)
a:302)
tWizard.java:107)
ion.java:98)
tem.java:502)
tionItem.java:435)
Re: - Problem creating new Visual Class with 3.0M7. [message #22570 is a reply to message #22424] Thu, 04 March 2004 09:17 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
What drivers of Eclipse, GEF, EMF, and VE do you have installed? The
latest (Thursday's 20040226) works, I think. This sounds like a mismatch
of drivers. Right now everything is very sensitive to all of the driver
levels. They don't mix and match very well.
Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #22613 is a reply to message #22570] Thu, 04 March 2004 09:45 Go to previous messageGo to next message
Hello Rich,
i've installed GEF-runtime-3.0M7
emf2.0.0_20040225_1234SL
VE-runtime-i20040226
VE-SDK-I20040226
regards Rolf
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> schrieb im Newsbeitrag
news:c27djj$l0p$1@eclipse.org...
> Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #22741 is a reply to message #22570] Thu, 04 March 2004 11:02 Go to previous messageGo to next message
Hello Rich,
you're right, i found a mismatch with eclipse sdk.
Thanks for your help
Rolf
> Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #22873 is a reply to message #22570] Thu, 04 March 2004 15:07 Go to previous messageGo to next message
would you please tell us what sets of drivers and eclipse do work
together rather than merely telling us that some don't mix and match
very well.
thank you
norwood sisson
> Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #22917 is a reply to message #22873] Thu, 04 March 2004 15:35 Go to previous messageGo to next message
It is listed on the download page for each VE driver. Each driver says
what levels must be used of Eclipse, GEF, and EMF.
Thanks, Rich Kulp
Re: - Problem creating new Visual Class with 3.0M7. [message #22960 is a reply to message #22917] Thu, 04 March 2004 18:03 Go to previous messageGo to next message
it would also be nice to know which version of java is compatible. the
eclipse pages tend to say thing like greater than 1.3 when 1.4 does not
work and greater than 1.4 when 1.4.0 does not work.
norwood sisson
Re: - Problem creating new Visual Class with 3.0M7. [message #23043 is a reply to message #22873] Fri, 05 March 2004 02:42 Go to previous message
Hello Norwood,
i'd installed the eclipse build from 20000225 mixed with ve/emf/ve build
from build 20040226
regards Rolf
<user@domain.invalid> schrieb im Newsbeitrag
news:c28238$hjt$1@eclipse.org...
> very well.
> thank you
> norwood sisson
> > Thanks,
> > Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #583357 is a reply to message #22424] Thu, 04 March 2004 09:17 Go to previous message
Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #583377 is a reply to message #22570] Thu, 04 March 2004 09:45 Go to previous message
Hello Rich,
VE-SDK-I20040226
regards Rolf
> Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #583421 is a reply to message #22570] Thu, 04 March 2004 11:02 Go to previous message
Hello Rich,
Rolf
> Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #583475 is a reply to message #22570] Thu, 04 March 2004 15:07 Go to previous message
very well.
thank you
norwood sisson
> Rich
Re: - Problem creating new Visual Class with 3.0M7. [message #583489 is a reply to message #22873] Thu, 04 March 2004 15:35 Go to previous message
Thanks, Rich Kulp
Re: - Problem creating new Visual Class with 3.0M7. [message #583503 is a reply to message #22917] Thu, 04 March 2004 18:03 Go to previous message
norwood sisson
Re: - Problem creating new Visual Class with 3.0M7. [message #583531 is a reply to message #22873] Fri, 05 March 2004 02:42 Go to previous message
Hello Norwood,
from build 20040226
regards Rolf
> very well.
> thank you
> norwood sisson
> > Thanks,
> > Rich
Previous Topic:GUI Designer?
Next Topic:Support for actions in GUI builder?
Current Time: Sun Aug 31 17:41:08 EDT 2025
Powered by FUDForum. Page generated in 0.06039 seconds
