Home » Eclipse Projects » Nebula » PShelf DND
PShelf DND [message #22401] Fri, 05 January 2007 00:23 Go to next message
Originally posted by: partyhut.internode.on.net
Hi all,
How can I add PShelfItem as a target of drag and drop? The DropTarget
constructor only accept Control as param...I tried to use
pShelfItem.getBody() as target. However it doesn't work. When I am
draging a item from shelf item 1 to shelf item 2, I can only see the
title panel of the shelf item 2, not the body control, so I couldn't
drop my item on it.... and the title part of the shelf item 2 doesn't
accept my drop action.
Re: PShelf DND [message #22482 is a reply to message #22401] Fri, 05 January 2007 11:01 Go to previous messageGo to next message
HS wrote:
> Hi all,
This is just a guess, but I think PShelfItem is a Widget and not a
Control, it is not eligible for drag events. What you probably want to
do is use the PShelf for the drop target, and when the user drops you
have to discover which shelf it was dropped on.
Matthew
Re: PShelf DND [message #22526 is a reply to message #22482] Sun, 07 January 2007 17:16 Go to previous message
Thank you Matthew! Normally, how would you decide which shelf it was
dropped on? Use X and Y value? First time do DND here :)
Matthew Hall wrote:
> HS wrote:
>> Hi all,
> Matthew
Re: PShelf DND [message #574301 is a reply to message #22401] Fri, 05 January 2007 11:01 Go to previous message
HS wrote:
> Hi all,
Matthew
Re: PShelf DND [message #574324 is a reply to message #22482] Sun, 07 January 2007 17:16 Go to previous message
Matthew Hall wrote:
> HS wrote:
>> Hi all,
> Matthew
Previous Topic:PShelf DND
Next Topic:grid viewer
Current Time: Tue Jul 22 01:47:05 EDT 2025
Powered by FUDForum. Page generated in 0.06404 seconds
