Home » Modeling » GMF (Graphical Modeling Framework) » Opening diagrams when double-clicking Labels within Top Level Nodes (OpenDiagramEditPolicies)
Opening diagrams when double-clicking Labels within Top Level Nodes (OpenDiagramEditPolicies) [message #228936] Wed, 06 May 2009 00:43 Go to next message
I wanted to allow a Label (within a Top Level Node) to have an
OpenDiagramEditPolicy in order to open up a new editor (diagram
partitioning). Adding it to the .gmfgen manually wasn't a problem, and
the relevant OpenDiagramEditPolicy is created and connected as expected.
However, when the Label is connected, sometimes getTargetEditPart() will
return the Label that was double-clicked, and not the ShapeNodeEditPart
representing the original node. It seems the Label does not have the
Style information in order to open up the correct diagram:
View view = (View) targetEditPart.getModel(); // returns a Node
Style link =
view.getStyle(NotationPackage.eINSTANCE.getHintedDiagramLink Style()); //
returns null
Following
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg08170.html
I added this to the OpenDiagramEditPolicy, and all works fine now:
public EditPart getTargetEditPart(Request request) {
if (understandsRequest(request)) {
if (getHost() instanceof ShapeNodeEditPart) {
return getHost();
return getHost().getParent(); // expect Node
return super.getTargetEditPart(request);
My question is: is this expected behaviour? i.e. Is it expected that the
Label does not have the Style information for the Top Level Node above?
If not, should I add this as a bug?
Cheers
Jevon
Re: Opening diagrams when double-clicking Labels within Top Level Nodes(OpenDiagramEditPolicies) [message #229533 is a reply to message #228936] Tue, 12 May 2009 07:56 Go to previous message
Hello Jevon,
I think GMF does not support linking a label with sub-diagrams for now (LabelMapping
is not a subclass of MappingEntry having "relatedDiagrams" reference).
If you think it is necessary to link LabelMapping with a sub-diagram then
please file a request for it.
Alex Shatalin
Previous Topic:Creating collections with at least one item
Next Topic:Animation in editor
Current Time: Fri Jul 18 07:00:07 EDT 2025
Powered by FUDForum. Page generated in 0.07661 seconds
